Mathematica - Analysis of a mass-damper-spring system
The discussion revolves around analyzing a mass-damper-spring system described by a second-order differential equation. Participants explore how to find the homogeneous solution, apply initial conditions, and determine the natural frequency of the system, including considerations of damping.
  • One participant presents the differential equation and seeks help in finding the homogeneous solution using Mathematica's DSolve command.
  • Another participant provides the output from DSolve but questions how to eliminate the constants C[1] and C[2] using initial conditions.
  • A suggestion is made to either evaluate the output function at the initial conditions or to include the initial conditions directly in the DSolve command.
  • A later reply confirms the correct format for including initial conditions in the DSolve command, leading to a solution without constants.
  • Discussion shifts to finding the natural frequency of the system, with one participant calculating the natural frequency for the undamped system and another noting the difference for the damped system.
  • Another participant calculates the damping ratio and provides the damped natural frequency, emphasizing the logarithmic decrease in amplitude due to damping.
Participants generally agree on the methods to solve the differential equation and apply initial conditions, but there is disagreement regarding the natural frequency, with different values presented for the damped and undamped systems.
Participants discuss the implications of damping on the natural frequency and the behavior of the system, but the exact relationship between the undamped and damped frequencies remains a point of contention.
Individuals interested in differential equations, mechanical systems, and the analysis of dynamic systems may find this discussion relevant.
Keesjanss
Hello,
I am currently working on a problem, but at the moment I am stuck. I just don't know how to solve the problem so I hope someone can help me with it. This is the question
1a : Consider the standard mass-damper-spring system:
m y''+γ y'+k y=u
where the constants have the following values:
m=28
γ=3
k=13
First find the homogeneous solution to the differential equation using the DSolve command. This is also known as the transient solution. In other words, find the solution where u(t)=0. Use the initial values y(0)=1 and y^\[Prime](0)=1.
(* Use Set to assign your answer to the variable before this comment *)(* \
Your answer should be in the default output form produced by DSolve, \
which is a Rule within Lists.
The form should look similar to the following: *)
1b : What is the natural frequency Subscript[\[Omega], 0] of this system?
Greets
This is what I have so far
DSolve[28 y''[t] + 3 y'[t] + 13 y[t] == 0, y[t], t]
{{y[t] ->
E^(-3 t/56) C[2] Cos[(Sqrt[1447] t)/56] +
E^(-3 t/56) C[1] Sin[(Sqrt[1447] t)/56]}}
Now is my question, how do I lose the constants C[2] and C[1]. I think it has something to do with that y[0]=1 and y'[0]=1, but I don't know how I should insert those values in the equeation.
You can do it one of two ways. The first is to take your output function and use it to evaluate y[0]==1 and y'[0]==1. That is two equations which you can solve for C[1] and C[2].
The other way is to add those initial conditions to the equations in DSolve. So instead of just solving the differential equation, make a list like {diffeq, y[0]==1, y'[0]==1} or {diffeq, y[0]==y0, y'[0]==v0}
Ok, but how do I exactly add those initial conditions in the equation
I have now : DSolve[28''y[t]+3y'[t]+13y[t]==0,y[t],t]
So where in the equation has the ''y[0]==1 andd y'[0]==1 be placed and which brackets do I have to use?
Oh I think I got it correct now :
DSolve[{28 y''[t] + 3 y'[t] + 13 y[t] == 0, y[0] == 1, y'[0] == 1},
y[t], t]
and now there no constants anymore in the equation.
But now is the next question : What is the natural frequency w0 of this system?
Someone who knows that?
Your mass is 28; spring constant or stiffness is 13. Radian natural frequency is sqrt(k/m) = 0.681 radians/sec or 0.1084 Hertz (cycles/sec).
If you want the natural frequency of the damped system, think what the cos and sin terms in the solution mean!
Ganesrk found the natural frequency of the undamped system, which is a different value.
damping ratio = c/(2sqrt(mk)) = 2/(2sqrt(28x13)) = 0.0786 | 7.8% critical damping
damped radian freq = unadamped radian freq x sqrt(1 - damping ratio^2) = 0.679
The amplitude of motion of the mass is logarithmically decreasing and it is a function of the damping ratio.
  • · Replies 0 ·
