Is (n^2+3)(n^2+15) divisible by 32 for odd positive integers n?
The discussion revolves around proving that the expression (n^2+3)(n^2+15) is divisible by 32 for all odd positive integers n. Participants suggest using mathematical induction, although the original problem does not explicitly require it. The initial case for n=1 shows that the expression equals 64, which is divisible by 32. The induction step involves evaluating the expression for n=k and n=k+1, leading to a formula that includes a term divisible by 32. The conversation emphasizes the importance of correctly applying the induction hypothesis to ensure the proof holds for all odd positive integers.
sushichan
Prove that (n2+3)(n2+15) is divisible by 32 for all odd positive integers n.
I suppose we are supposed to use mathematical induction since it is in that chapter, but the following questions specifically state that we should use induction but this question doesn't.
n=1
(1+3)(1+15)=64=2*32​
n=k
(k2+3)(k2+15)=32A, A∈ℝ​
n=k+1
⇒((k+2)2+3)((k+2)2+15)
= (k2+3)(k2+15) + 8k3+24k2+104k+88
= 32A + 8(k3+3k2+13k+11)​
sushichan said:
A∈ℝ
You don't mean that.
sushichan said:
n=k+1
Think about that choice again. Note that it says:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
