Mathematical Induction: Prove Sum of Arithmetic Sequence
In summary, the arithmetic sequence \{a+kd\}_{k\in\mathbb{N}\cup\{0\}} has the following property:\sum_{k=0}^n a+kd = \frac{1}{2}(n+1)(2a+nd)[1]
Oxymoron
870
Question
Suppose [itex]a,d \in \mathbb{Z}[/itex] and consider the arithmetic sequence [itex]\{a+kd\}_{k\in\mathbb{N}\cup\{0\}}[/itex]. Use the Principle of Mathematical Induction to prove that
[tex]\sum_{k=0}^n a+kd = \frac{1}{2}(n+1)(2a+nd)[/tex]
[1] try it for the base case(guess its n=1 not n=0 summation starts at 1)
[2] assume it for some n-1 OR n
[3] show that [2] leads to n OR n+1
(depends on if your more comfortable n-1 --> n OR n-->n+1
majority of cases they are the same but sometimes its easier to see one over the other)
I suggest if you want more help that you first show us what you've done first.
You're too quick Neurocomp :smile: , I was typing my solution.
Solution
Let [itex]P(n)[/itex] be that statement that
[tex]\sum_{k=0}^n a+kd = \frac{1}{2}(n+1)(2a+nd) \quad \dag[/tex]
1. Show that [itex]P(1)[/itex] is true:
[tex]P(1) = \sum_{k=0}^1 a+kd = (a+0d)+(a+1d) = 2a + d \quad \ddag[/tex]
For [itex]n=1[/itex] the RHS of [itex]\dag[/itex] equals
[tex]\frac{1}{2}(1+1)(2a + 1d) = 2a+d = \ddag[/tex]
2. Assume true for [itex]P(n)[/itex].
3. Prove true for [itex]P(n+1)[/itex]. That is [itex]P(n+1) = \frac{1}{2}(n+2)(2a+(n+1)d)[/itex]:
[tex]\sum_{k=0}^{n+1} a+kd &=& \sum_{k=0}^n a+kd + \sum_{k=n+1}^{n+1} a+kd[/tex]
[tex]\quad= \sum_{k=0}^n a+kd + [a + d(n+1)][/tex]
[tex]\quad= \frac{1}{2}(n+1)(2a+nd) + a + d(n+1)[/tex]
[tex]\quad= a(n+1) + a + \frac{1}{2}dn(n+1) + d(n+1)[/tex]
[tex]\quad= a(n+2) + \frac{1}{2}d(n+1)(n+2)[/tex]
[tex]\quad= \frac{1}{2}(n+2)(2a + (n+1)d)[/tex]
[tex]\quad= P(n+1)[/tex]
[tex]\square[/tex]
It may be hard to see what I've done in going from
[tex]a(n+2) + a + \frac{1}{2}dn(n+1) + d(n+1)[/tex]
to the next line.
All I've done is group the a and [itex]\frac{1}{2}d(n+1)[/tex]
So
[tex]\frac{1}{2}dn(n+1) + d(n+1) = \frac{1}{2}\left[dn(n+1) + 2d(n+1)\right][/tex]
[tex] = \frac{1}{2}d\left[n(n+1) + 2(n+1)\right][/tex]
[tex] = \frac{1}{2}d(n+1)\left[n+2\right][/tex]
1. What is mathematical induction?
Mathematical induction is a method of proof used to show that a statement is true for all natural numbers. It involves proving the statement is true for the first number, usually 1, and then showing that if the statement is true for any number, it must also be true for the next number.
2. How is mathematical induction used to prove the sum of an arithmetic sequence?
To prove the sum of an arithmetic sequence using mathematical induction, we must first prove that the formula for the nth term of the sequence is correct. Then, we show that the formula holds true for the first term of the sequence. Finally, we use mathematical induction to show that if the formula is true for any term, it must also be true for the next term, thus proving it true for all terms.
3. What is an arithmetic sequence?
An arithmetic sequence is a sequence of numbers where the difference between consecutive terms is constant. For example, 2, 5, 8, 11, 14 is an arithmetic sequence with a common difference of 3. The formula for the nth term of an arithmetic sequence is an = a1 + (n-1)d, where a1 is the first term and d is the common difference.
4. How do you prove the sum of an arithmetic sequence using mathematical induction?
To prove the sum of an arithmetic sequence using mathematical induction, we first prove the formula for the nth term of the sequence is correct. Then, we show that the formula holds true for the first term of the sequence. Finally, we use mathematical induction to show that if the formula is true for any term, it must also be true for the next term. This proves the formula for the sum of an arithmetic sequence is true for all terms.
5. Can mathematical induction be used to prove other mathematical statements?
Yes, mathematical induction can be used to prove various mathematical statements, not just the sum of an arithmetic sequence. It is a commonly used method of proof in many areas of mathematics, including number theory, combinatorics, and calculus.
  • Precalculus Mathematics Homework Help
  • Set Theory, Logic, Probability, Statistics
  • Math Proof Training and Practice
  • MATLAB, Maple, Mathematica, LaTeX
