Matlab: Fitting to two functions simultaneously
5 replies · 12K views
Sonolum
Okay, here's a problem that I've been struggling with for a few weeks.
I'm conducting a series of measurements, where I get two sets of data, i.e. one xdata value gives me two ydata values. I want to curve fit the two data sets to two different functions, F1 and F2, that depend on the same coefficients. By fitting ydata1 to F1 and ydata2 to F2, I hope to extract the coefficients that best fits to both data sets.
While I can fit to F1 or F2 separately, I can't seem to fit to both at once. The curve-fitting tool doesn't seem capable of this, and I've been playing around with lsqcurvefit but with no success. I haven't found any other functions that seem able to do what I want.
The thing is, I was able to set this fit up in a graphing program called Sigmaplot. In that program, I combined my data sets into one by copying one after the other, and then created another variable d which I defined as 0 for all the ydata1 points and 1 for all ydata2 points--
i.e. xdata=[xdata , xdata]; ydata=[ydata1 , ydata2]; d=[0,...,0,1,...,1]
Then I added an if statement in my fitting model, saying "if d==0, fit to F1, else fit to F2".
It works, but it's a pain because I have to manually enter the data and set up the fits and initial guess values by hand. I was hoping to use Matlab to set everything up automatically, but my attempts to do something similar haven't worked. Any suggestions would be greatly appreciated.
Seems a little odd that both functions would have the same parameters, but if that's the case, I think the least squares problem would be:
[ATA + BTB]z = ATy1 + BTy2
Can't you just assemble the matrices A & B and perform the calculations with Matlab to solve for z? Maybe I'm looking at this too simplistically.
I think you may be onto something here!
I have been trying to write an if/else loop to create the two functions to fit to, which MatLab seems to vehemently dislike. Phrasing the problem in the manner you've suggested makes it a minimization of a matrix problem, instead of an lsqcurvefit problem, which (hopefully) MatLab will like a bit better.
Thank you, I will give it a try and see if it'll work this way, I really appreciate it! However, if it's all fail, then I'll be back to prod the internet community's collective brain for additional assistance. In the meantime, thank you again!
I also have same problem for fitting my data, help me toooooooooo
Soooooo... I think we might have a solution, though I'm still working out all the details on Matlab...
We're trying to use the surface fitting tool to fit to both functions.
I will update this thread as soon as I get it working with better instructions!
Best wishes, and if you figure this out before I do, please let me know!
I found!
Origin 8 can do this. We can do complex fitting also.
try...
http://wiki.originlab.com/~originla/howto/index.php?title=Tutorial:Fitting_Complex_Function
