Matrix inversion with complex numbers? or faster way?
13 replies · 8K views · last reply
asdf12312
matrix inversion with complex numbers?? or faster way?
i managed to get the answer, but it took me like 30min. to work this by hand. i probably worked it differently than my instructor's method above, but wat i did was get the coefficients of V on one side, coefficient of V(ex) on the other side.
(3/0.2 + 1/(0.1+j0.1))V = (1/(0.1+j0.1))Vex
(20-5j)V = (5-5j)Vex
V=((5-5j)/(20-5j))Vex
V=(0.343<-30.96)Vex
which in fact did equal V=[0.294− j0.176]Vex when i converted to rectangular form. the problem is, this took me way too long to work, i was wondering if there was an easier way. like perhaps matrix inversion with complex numbers? i still have no idea how that works. because i have a test on this and if i spend 30min. to simplify equation like this, and plus this isn't even the answer to the problem, it's just one equation. is there an easier way??
i have a calculator, i used it for some of the simpler calculations actualy . just don't know how to use matrix inversion for a problem liek this.
If it takes you 30 min. to do the calculations in the OP with a calculator, matrix inversion will not be any quicker.
should it not take 30min? maybe the method i used to do it was slow, i had to convert between rectangular and polar form a lot. plus i had to do multiplication with complex numbers by hand. couldn't do it with calculator.
For multiplication and division, work exclusively in polar form. When you obtain a final answer, you can convert it to rectangular, if you wish.
If someone tells you how to solve the problem by matrix inversion, how would you carry out the inversion? By hand? If you have to do complex arithmetic by hand, how do you plan to invert a matrix having complex numbers among the elements of the matrix?
If you try to invert a matrix by hand, the amount of number crunching involved won't be any easier than just solving the equations directly.
I can't believe you don't have a calculator that can do complex arithmetic.
You should get a TI-86 or a HP50G. You can find a TI-86 on eBay for $20 to $30. Right now I see an HP50G for a good price:
http://www.ebay.com/itm/BEAUTIFUL-HP-50g-Graphic-Calculator-NEVER-USED-/151039652398?pt=Calculators&hash=item232aaa322e
Both calculators can do complex arithmetic, including matrix inversion with complex entries.
Edit: You can also solve problems like this with resources available on the web, such as Wolfram Alpha.
I have a TI-83 plus. i can do normal matrix inversion but i don't know if i can do it with complex numbers.
Your TI-83 plus does complex number operations as a standard feature. It can convert between rectangular and polar form. It should not take you 30 min. to do the calculations listed in the OP. It would help you a lot to review the guidebook for this calculator. If a guidebook did not come with your calculator, you can download one from here:
http://education.ti.com/en/us/produ...g-calculators/ti-83-plus/downloads/guidebooks
thanks very much! i actually decided to google it, found a site that had very easy to follow instructions: http://www.tc3.edu/instruct/sbrown/ti83/complx83.htm#Display
just managed to get the answer in like 10sec..i obviously was doing it wrong, haha. i didn't know my calculator could convert from rectangular to polar form or do complex number oprations, so i was doing it myself, just plugging in values into the calculator. like tan^-1(y/x) to find the angle. and yah, i don't think i need matrix inversion then.
also, i know its easier to use polar form for multiplication/division, my book just had a shortcut method that involved multiplying complex numbers this way: 1/(1-1i) = [1/(1-1i)] * [(1+1i)/(1+1i)] so it would get rid of any imaginary part in the denominator, since i^2=-1, so the answer would be (1+1i)/2 = 0.5+0.5i. this is what i meant by doing it by hand. but obviously with my calculator i can do this in like 1 sec.
OK, just found out i cannot input complex numbers into matrices on my ti-83 plus. i have an exam coming up pretty soon, and here is a part requiring to solve simultaneous equations from a sample problem my teacher said might show up on it:
so i was wondring, is solving simulatneous equations with complex numbers doable by hand/calculator without matrix inversion, and if so how long that would take? if it helps using my calculator i worked out the matrix elements to be:
Code:
  [B]V1           V2 [/B]
[0.4+0.1i     -0.2] = [4.2]
[-0.2     0.4+0.1i] = [-2.1]
You can use Cramer's rule.
thanks. just finished my exam, went in there hoping for at most a 2x2 complex-number matrix because that's all i knew how to calculate, turns out there was only one problem like this and with a single node circuit too. so basically just a 1x1 matrix. which was easy, just used my calculator, no detreminants at all. thanks anyway :D
