MHB What is the Maximum Inclination of a 3D Plane and its Equation in the XY Plane?
  • Thread starter Thread starter cptolemy
    Max Plane
The maximum inclination of a 3D plane represented by the equation Ax + By + Cz = 0 is achieved when it is perpendicular to the intersection line with the reference plane. The slope of this maximum inclination line can be determined by taking the negative reciprocal of the slope of the intersection line, given as -1/m. If the intersection line is horizontal (slope m = 0), the perpendicular line is vertical and does not have a defined slope. Understanding these relationships is crucial for accurately determining the inclination in the XY plane. The discussion clarifies the geometric principles involved in these calculations.
cptolemy
Hi,
If I have a 3D plane Ax+By+Cz=0, and I know the line equation of its intersection with the reference plane, what is the maximum inclination a point can have and what is its equation in the xy plane?
Is it perpendicular to the intersection? That is , if the slope of the intersection line is m, the max will be given by the line with a slope of -1/m?
This is embarassing...
Cheers,
Kepler
Mathematics news on Phys.org
If I understand what you mean by "inclination" then, yes, the plane with maximum "inclination" to a given plane is perpendicular to it. And, yes, if a line is perpendicular to a line with (non-zero) slope m, then it has slope -1/m. Note that if m= 0, so "horizontal", then the perpendicular line is "vertical" and does not have a defined slope.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
