Max/Min of Polynomial Functions
To find the maximum and minimum of polynomial functions without using calculus, completing the square is effective for quadratics, while special techniques can apply to other polynomials. Knowing the zeros and their multiplicities helps identify potential extrema, as max and min points occur between the zeros. A double zero indicates that the point is either a maximum or minimum based on the sign of surrounding terms. However, these methods provide limited insight compared to derivative tests. Overall, while there are alternative approaches, calculus remains the most comprehensive method for analyzing polynomial functions.
ddrsakuramax
Does anyone know a possible equation or way to solve for the Max and Min of a Polynomial Function without Calculus or the Derivative test??
I do if it's a quadratic. Complete the square. You can do similar tricks with some other special polynomials. Otherwise it's using derivatives.
What if you are given the zeroes and the multiplicity of the zeroes?
It will tell you that the maxs and mins that aren't at zero are between the zeros, but it won't tell you much more about them. If you have, for example, a double zero at a, (x-a)^2 is a factor of the polynomial and you can say x=a is a max or a min depending on the sign of the rest of the terms, that is true.
ooo alright thanks a lot!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
