Max Voltage Across Capacitor & Resistor in a Circuit
1 reply · 2K views
GalMichaeli
For the circuit in the picture below, with [itex]V_{c}(t=0) = 0[/itex] and a voltage source with period T described by
[tex]V_s(t) = \sum_{-\infty}^\infty (-1)^{n}g(t-nT)[/tex]
where
[tex]g(t) = 7[u(t)-u(t-T)]\quad [Volt][/tex]
and [itex]u(t)[/itex] is a step function described by
[tex] u(t) =<br /> \begin{cases}<br /> 1 & \text{if } t \geq 0 \\<br /> 0 & \text{if } t < 0<br /> \end{cases}[/tex]
What is the maximal voltages across the capacitor?
What is the maximal voltages across the resistor?
The voltage source is a pulse train with amplitude [itex]\pm 14 \quad [Volts][/itex] and since at time [itex]t = 0[/itex] we may consider the cap. as a short-circuit, we have [itex]V_{R}(t=0) = 14 \quad [Volts].[/itex]
I'm having trouble figuring out what the maximal voltage across the cap. is.
Should I apply transient analysis?
Thanx.
First, never mind the voltage anywhere at t=0. You don't know what t=0 is. This voltage wavetrain has been running since t = -∞.
Now my gut reaction was Fourier series. But that's the hard way. Instead:
1. realize that v(t), the voltage across C, will vary symmetrically about zero volts since that is the average value of your input, from Vmin to Vmax = |Vmin|.
2.Then realize that the most negative C voltage is just before the input goes from -E to +E (why?). Then realize by symmetry that the max C voltage will occur just before the input transitions from +E to -E (again, be able to justify this statement).
3. Write the KVL: current thru R = current into C starting with t=0 at the -E to +E input transition. This will be a differential equation, easy to solve, in capacitor voltage v(t). Solve with the initial condition v(0+) = Vmin, then solve for v(T) = Vmax. The rest should "follow immediately" as the textbooks say.
