How Can Lagrange Multipliers Determine Maximum Shannon Entropy?
The discussion focuses on using Lagrange multipliers to determine maximum Shannon entropy under the constraint that the sum of probabilities equals one. The Lagrangian is set up as L(x, λ) = -∑ p(x) log₂ p(x) - λ(∑ p(x) - 1). The participant is unsure about taking partial derivatives with respect to p(x) and λ, particularly regarding the summation signs. It is clarified that the partial derivatives should yield the constraint functions and that using an index for the sample space can simplify the equations. The resulting system of equations involves d+1 equations for d+1 variables, allowing for the determination of maximum entropy.
Irishdoug
Given a random variable X with d possible outcomes and distribution p(x),prove that the Shannon entropy is maximised for the uniform distribution where all outcomes are equally likely p(x) =1/d
## H(X) = - \sum_{x}^{} p(x)log_{2}p(x) ##
##log_{2}## is used as the course is a Quantum Information one.
I have used the Lagrange multiplier way of answering. So I have set up the equation with the constraint that ## \sum_{x}^{} p(x) = 1##
So I have:
##L(x,\lambda) = - \sum_{x}^{} p(x)log_{2}p(x) - \lambda(\sum_{x}^{} p(x) - 1) = 0##
I am now supposed to take the partial derivatives with respect to p(x) and ##\lambda##, however the derivatives with respect to ##\lambda## will give 0 I believe as we have to constants, 1 and -1.
So ##\frac{\partial (- \sum_{x}^{} p(x)log_{2}p(x) - \lambda(\sum_{x}^{} p(x) - 1)) }{\partial p(x)} = -(log_{2}p(x) + \frac{1}{ln_{2}}+\lambda) = 0##
I am unsure what to do with the summation signs, and I am also unsure how to proceed from here. Can I please have some help.
The partials with respect to ##\lambda## should recover your constraint functions since the ##\lambda## dependent terms in your Lagrangian are only ##\lambda## times your constraint functions. Also consider using an index:
Sample space is ##\{ x_1, x_2, \cdots x_d\}## and ##p_k = p(x_k)##
L(p_k, \lambda) = -\sum_{k} p_k \log_2(p_k) - \lambda C(p_k)
with ##C## your constraint function ##C(p_k) = p_1+p_2+\ldots +p_d - 1## and normalized probabilities equate to ##C=0##.
\frac{\partial}{\partial p_k} L =\frac{1}{\ln(2)} -\log_2(p_k) -\lambda \doteq 0
\frac{\partial}{\partial \lambda} L = C(p_k) \doteq 0
(using ##\doteq## to indicate application of a constraint rather than an a priori identity.)
This is your ##d+1## equation on your ##d+1## free variables ##(p_1, p_2, \ldots ,p_d, \lambda)##.
  • · Replies 0 ·
