Discovering the Maximum Value of a Quadratic Equation
  • Thread starter Thread starter 3.141592654
    Quadratic
The discussion focuses on maximizing the quadratic function f(X)=6X-1/2X^2+82, with the maximum occurring at X=6. The transformation from -1/2(X^2-12X) to -1/2(X-6)^2+18 is clarified through the method of completing the square. Participants explain how to manipulate the quadratic expression to identify its maximum value and the relationship between the two forms. The conversation also touches on the axis of symmetry for parabolas and its relevance to finding maxima and minima. Completing the square is emphasized as a key technique for understanding these transformations in quadratic equations.
3.141592654
Maximizing the function f(X)=6X-1/2X^2+82. That's it, so 6X-1/2X^2+82 = 82-1/2(X^2-12X) = 82-1/2(X-6)^2+18. So f(X)=100-1/2(X-6)^2. Since (X-6)^2 is positive for any X not =6, than the max is x=6. The part I don't understand is when rearranging the function, how do you get from -1/2(X^2-12X) to -1/2(X-6)^2+18?
The focus of the problem assumes my question is already common knowledge, so I don't think there are any relevant equations.
Not sure what to do, at first I worked backwards trying to expand (x-6)^2+18, which is X^2-12X+54, but I'm at a dead end. This isn't actually for a class, but thanks for your help in advance!
Expand -\frac{1}{2}(x-6)^{2} and tell us how much smaller it is than -\frac{1}{2}(x^{2}-12x)
:smile:
alright, so -1/2(X-6)^2 expanded =-1/2X^2+6X-18. 18 smaller than -1/2(X^2-12X). Very helpful, thank you. That answers my question, but this brings me to another question. If given -1/2(X^2-12X), is there a way to use calculation to find that it equals -1/2(X-6)^2+18? I guess what I am asking is how can I look at this function, -1/2(X^2-12X) and then determine that it is equal to -1/2(X-6)^2+18? Do you factor an x and expand or is there any way to do this? Thanks again!
This involves a method known as completing the square. Have you learned that?
It is known as completing the square
If I have some quadratic of the form say...ax^2 + bx + c then first I can factor out an a to get
a(x^{2} +\frac{b}{a}x + \frac{c}{a})
Then I can add and subtract (\frac{b}{2a})^{2} to get
a(x^{2} +\frac{b}{a}x + \frac{b^{2}}{4a^{2}} - \frac{b^{2}}{4a^{2}} + \frac{c}{a})
Which can then be converted to
a((x +\frac{b}{2a})^{2}) + d) where d = \frac{c}{a} - \frac{b^{2}}{4a^{2}}
You can of course pull d out of the brackets where it would then be equal to c - \frac{b^{2}}{4a}
Is it part of your knowledge that the axis of symetrry of a parabola of the form y= ax^2 + bx + c is the line x=-b/2a. They introduced that to us in Australia before applying Completing the square for maxima/minima. If you do, and say the parabola is concave down - where does the maximum value always occur?
  • · Replies 39 ·
  • · Replies 22 ·
