Maximizing the distance of a projectile
  • Thread starter Thread starter IDumb
    Projectile
The discussion revolves around determining the optimal angle to maximize the distance of a projectile, specifically in the context of spitting. The problem involves analyzing projectile motion with an initial height and varying launch angles.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the launch angle and the components of initial velocity. One participant attempts to derive the maximum distance by substituting the velocity components into the equations of motion and differentiating with respect to the angle.
The conversation is ongoing, with participants exploring different scenarios, such as the effect of initial height on the optimal angle. Some express uncertainty about the implications of their findings, particularly regarding how the launch angle might depend on the initial speed.
There is a noted complexity when the initial height is not zero, leading to more complicated equations and potential errors in differentiation. Participants are questioning the assumptions made about the relationship between angle and initial speed.
IDumb
1) This is not a homework problem, just a question I came across and can't solve adequately.
2) Sorry if this is wrong area to post it.
What angle would be best to hold your head at relative to ground to maximize the distance you can spit.
I drew a diagram, horizontal axis was distance in the x direction, vertical axis was distance in y direction. I drew a vector for velocity, V0 at an angle [tex]\theta[/tex] relative to ground. vx and vy represent the x and y components of this initial velocity vector. The initial velocity starts from a height of h.
I then divided it into 2 equations, the acceleration in the y and x directions.
The Y direction:
ay = -9.8 (m/s2)
integrate twice to obtain position function:
py(t) = -4.9t2 + vyt + h
Next, I found the time, t1, that the projectile (saying spit sounds weirder) would reach ground, at y = 0.
py(t1) = 0
using the quadratic equation I obtained 2 results, 1 of which had to be negative. So the other one is the time we want.
t1 = Vy/9.8 + (1/9.8)([tex]\sqrt{v<sub>y</sub><sup>2</sup> + 19.6h})<br /> <br /> OK, so at this time, we will have y = 0 and x = D, the farthest distance the projectile will reach.<br /> <br /> The x equation:<br /> a<sub>x</sub> = 0 --> v<sub>x</sub>(t) = v<sub>x</sub> --> p<sub>x</sub>(t) = v<sub>x</sub>t<br /> <br /> replace t with the value found for t1, because that will give us an equation for D, the maximum distance.<br /> v<sub>x</sub>(t1) = D = \frac{v<sub>x</sub>v<sub>y</sub>}{9.8} + (1/9.8)(v<sub>x</sub>\sqrt{v<sub>y</sub><sup>2</sup> + 19.6h)[/tex]
Okay, so how are vx and vy related to the launch angle and the projectile speed?
meh, sorry, had some issues posting it must have gotten deleted.
I subbed in vx = v0cos([tex]\theta[/tex]) and vy = v0sin([tex]\theta[/tex]). Then i took dD/d[tex]\theta[/tex]. Set it = 0, used a computer to solve it.
at angle of 45
NEILS BOHR said:
at angle of 45
Sure, if h = 0. What if h [tex]\neq[/tex] 0?
That's the issue. At h = 0 it simplifies easily. I get a messy equation for D with respect to theta. Leading to stupid mistakes when taking the derivative to find the critical points. I used a computer to solve what I had, and I got angles that varied with both height and the magnitude of the initial speed. That can't be right though, the angle shouldn't vary with the initial speed's magnitude.
  • · Replies 23 ·
  • · Replies 30 ·
