Maximum acceleration up ramp
To determine the maximum acceleration of a remote-controlled car on a 20-degree incline, a free body force diagram is essential. The maximum acceleration can be calculated using the formula: a = (-mg(sin20) + mgcos20) / m. The static friction coefficient of 0.70 and the normal force, derived from mgcos20, are crucial in this calculation. The mass cancels out in the equation, simplifying the process. Understanding the cancellation of mass terms is key to solving the problem effectively.
diffusion
You are trying to have your remote-controlled car leap off a ramp, which happens to be at a 20 degree incline to the ground. If the coefficients of static and kinetic friction are .70 and .50, repsectively, what is the maximum possible acceleration of the remote-controlled car up the ramp?
Hi,
Have you drawn a free body force diagram? Also we need to see your attempt at the solution before we can help you.
Not sure how to find the solution, but I'll wing it.
Max acceleration = -mg(sin20) + max static friction / mass.
Max static friction = static coefficient x normal force = 0.70 x n
Find n (Net force in y-direction) = mgcos20.
Now you plug mgcos20 back into the original equation
-mg(sin20) + mgcos20 / mass.
Stuck here.
Looks like you knew more than you thought. :wink:
Stuck here.
Looks good to me. Realize that mass = m, so it cancels. And use parentheses, to reduce mistakes. I'd write that as:
a = ( -mgsin20 + mgcos20 )/m
I realize this is going to be a stupid question, but how do they cancel? In the numerator you have two mg's, only one in the denominator. Isn't that going to leave you with another m?
No. Each term in the numerator has a single "m". It factors out like so:
mX + mY = m(X + Y)
mX + mY = m(X + Y)
Gotcha. Thanks.
  • · Replies 32 ·
  • · Replies 16 ·
