Maximum Acceleration with Given Mass and Tension?
9 replies · 3K views · last reply
kamalpreet122
A 2.00X101 kg mass is pulled upwards with constant acceleration by a cable attached to a motor. The cable can withstand a maximum tension of 5.00X102 N. What is the maximum acceleration possible?
The answer sheet says the answer is 15.2m/s2
F=ma
F=ma
F/m = a
500/20 = a
25 m/s2= a
some1 please tell me what i did wrong :-(
You have to accout for the acceleration due to gravity!
Edit: Your too fast for me Apphysicist !
Indeed! F=ma is your net force = m* net acceleration. If you apply your maximum tension upward, gravity still acts downward (sum the forces for your net force, don't forget that gravity gets a minus-sign because it acts in the opposite direction of your upward tension). Then use F=ma.
kamalpreet122 said:
so the formula would be changed to F= (mg)a ?
No, it would be changed to (T-mg)=ma.
Do you see why?
yeaaa kinda ..soo the total weight subtracted from Tension gives me the net force then i apply the forumlaa .. OH that makes so much senseee =) THNXXX :D
man yur great =P i have a really tough question i was not able to figure out want to help me with that :$
Right. It's much easier to think about F=ma really being:
[tex]\sum_{\text{all}}\bold{F}\,=\,m \bold{a}[/tex]
So it's a sum of all your vector forces (the bold meaning it's a vector...so for your problem, the +/- indicates the direction is all, since there are no components, it's just in one direction).
