Maximum bending moment and maximum deflection of the spring?
To determine the maximum bending moment and maximum deflection of a coil spring under compression, it is essential to recognize that the loading does not produce a bending moment, as the load is applied vertically. Instead, the maximum deflection occurs when the coils touch, and the spring is fully compressed. The analysis of such springs involves torsion rather than bending, and relevant formulas can be found in resources like "Shigley’s Mechanical Engineering Design" or "Roark’s Formulas for Stress and Strain." Understanding the distinction between bending moments and torsional loading is crucial for accurate calculations. Proper application of these principles will lead to the correct assessment of spring behavior under load.
metalsunsuccess1
TL;DR Summary
How do I find the maximum bending moment and maximum deflection of the spring?
How can I find the maximum bending moment and maximum deflection for a spring?
It would be very helpful if you could explain the specific procedure and formula in an easy-to-understand manner.
that's all, thank you very much.
What kind of spring is this?
Thank you for your reply.
This assumed mechanical spring is a coil spring, and the lower part is placed on a table (not fixed), and a concentrated load is applied from above in the compression direction.
Thank you.
Thank you.
So how is there a "bending moment"? The loading you described wouldn't produce one.
The "maximum deflection" of a compression coil is when the clearance between the coils is zero.
Helical springs subjected to compression are calculated for torsion. You can find the formulas for example in "Shigley’s Mechanical Engineering Design" or in "Roark’s Formulas for Stress and Strain".
Likes cherish, Chestermiller and berkeman
It looks like you saw the units [N.m] or [lbf.ft] somewhere and thought it was bending moment, but springs are usually loaded in pure torsion, which uses the same units, but the meaning is completely different.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
