How Do You Calculate Maximum Bending Stress in a Beam with Limited Information?
The discussion focuses on calculating maximum bending stress in a beam with limited information. The user initially struggles with insufficient data, particularly regarding forces and distances at point A. They correctly calculate the reaction force at B and the moment at B but are unsure about finding the moment of inertia (I) and the distance (c). After clarification, they determine that only the moment of inertia for the strong axis is needed and correctly compute the maximum stress using the formula σ = M/S. The final maximum bending stress is confirmed to be 9.5 ksi.
joemama69
Note the attachment. I scanned it out of my book and I drew a FBD on it.
Ok so i haven't gotten very far at all with this one because it just doesn't seem to have enough information.
So first I summed the forces in the y direction.
Fy = 0 = 9k - RB... RB = 9k
Then I found the Moment @ B
MB = 9k(192) = 1728k
and that's about as far as I got. It seemed odd that there was no information given about the forces or distances at point A.
so I know that the Bending stress = -My/I
but how do I find the y. I am assuming it would come from k = 1/p but I do not know any of those quantities. Same with I = integral y2dA. Can I get a hint as to my next step
There is a force at A (and B), but the max bending moment at B (in inch-kips) is the same on either side of support B, so you don't need the force at A to calculate it. You should calculate the moment of Inertia , I, of the wide flanged beam, using the parallel axis theorem. Ignore the small fillets where the web connects to the flanges.
Ok so find I i used an equation from wikipedia
http://en.wikipedia.org/wiki/Second_moment_of_area#Parallel_axis_theorem
I calculated it for Ix & Iy, but it my book it doesn't specify which ones to use. do i add them together or did i use the wrong formulas
Ix = 1995 & Iy = 75
my book says for doubly symmetric shapes... \sigmamax = M/S where S = I/c
where do I go from here
The beam is bending about the strong axis of the beam, not the weak axis, so you just need to use the I that applies, not both. You don't add the moments of inertias. Don't forget your units of I (in^4). I assume you understand the value to use for 'c' ?
Ok so i used the Iy because that is the direction of movment = 75 in^4
and c would just be half of the height because it is a symetric beam
S = I/c = 75in^4/11in = 6.81in^3
\sigma = M/S = 1725kip*in/6.81in^3 = 254 kips/in^2
is this correct
You've got your Ix and Iy mixed up. But you managed to get the correct c distance.
ok I missunderstood
S = 1995/11 = 181.4 in^3
Stress max = M/S = 1728kips*in / 181.4 in^3 = 9.5 is kips/in^2 = psi
yes, that's 9.5 kips/in^2, or 9.5 ksi, or 9500 psi.
