Maximum displacement in mass spring system
The discussion centers on calculating the maximum displacement (X) of a block suspended by an ideal spring with a force constant (K) when subjected to a constant external force (F). The equation derived is X = F/K, but a discrepancy arises as the textbook states X = 2F/K. The participants clarify that the maximum extension occurs when the spring force equals the sum of the weight (mg) and the external force (F), acknowledging that inertia allows the block to extend further after equilibrium is reached.
  • Understanding of Hooke's Law and spring constants
  • Basic principles of mechanics, including forces and equilibrium
  • Knowledge of kinetic energy and its relation to motion
  • Ability to manipulate algebraic equations for problem-solving
  • Study the principles of oscillatory motion in mass-spring systems
  • Learn about energy conservation in mechanical systems
  • Explore the concept of damping in spring systems
  • Investigate the effects of varying force applications on spring displacement
Students in physics, mechanical engineers, and anyone studying dynamics and oscillatory systems will benefit from this discussion.
Fitz Watson
A block is suspended by an ideal spring of the force constant K. If the block is pulled down by applying a constant force F and if maximum displacement of the block from its initial position of rest is X then, find the value of X.
mg + F = XK + K(mg/K)
Let mass of block = m
Before applying F, the block is at rest. Let extension of spring here be a. So,
aK = mg
Hence, a = (mg/K) ... {1}
Now, after the block comes in equilibrium under F,
F + mg = (X+a) K ..... {2}
Solving {1} & {2} gives:
X = F/KBut, my book says that X = 2F/K
It does not say that it comes to equilibrium. The force is maintained as a constant.
But when it has reached maximum extension, doesn't it mean that now the spring force is equal to weight + external force applied. And that's why the block can't go further down
Not necessarily. Think about KE.
Now that I rethink, will it be like after forces becoming equal, block will go further down due to inertia?
Yes.
  • · Replies 18 ·
  • · Replies 58 ·
