Maximum flow rates through water turbines given power and head.
The discussion focuses on calculating maximum flow rates through Francis and Samson turbines based on specified power outputs and head measurements. The Francis turbine has a maximum power output of 0.15 kW with an efficiency of 79.7% at full power, while the Samson turbine has a maximum power output of 1.38 kW with an efficiency of 82.0% at full power. The flow rate is calculated using the formula: Flow rate = Power / (turbine efficiency * density of water * acceleration due to gravity * head). The calculations provided yield flow rates of 0.064 m³/s for the Francis turbine at full power and 0.046 m³/s at half power.
  • Understanding of turbine efficiency and its impact on performance
  • Familiarity with the principles of fluid dynamics
  • Knowledge of basic physics equations related to power and flow rates
  • Ability to perform unit conversions and arithmetic calculations
  • Research the impact of head height on turbine efficiency
  • Learn about the differences between Francis and Samson turbine designs
  • Explore advanced fluid dynamics concepts related to turbine performance
  • Investigate the role of water density in flow rate calculations
Engineers, hydrologists, and students studying mechanical or civil engineering, particularly those interested in water turbine design and performance optimization.
PhysicsStudy
Calculate the maximum flow rates through the Francis and the Samson turbines under the conditions specified:
Table 1 Characteristics of some American water turbines, 1849–97, on the basis of 30-inch (760 mm) wheel and 12-inch (300 mm) head
Type | Maximum power output | Efficiency (%)
Francis | 0.15 kW / 0.20 horsepower| 79.7 at full power / 55.0 at half power
‘Samson’ | 1.38 kW / 1.85 horsepower | 82.0 at full power / 75.6 at half power
Power = turbine efficiency * density of water * acceleration due to gravity * head * flow rate
so
Does anyone know if the efficiency in this equation should be given as a percentage or fraction? i.e. 79.7% or 0.797
Francis example...
Density of water = 1000kg/m^3
Acc due to gravity = 9.81 m/s^2
At full power:
Flow rate = 150/(0.797*1000*9.81*0.3)=0.064m^3/s
At half power:
Flow rate= (150/2)/(0.55*1000*9.81*0.3)=0.046m^3/s
However I have a feeling I'm missing a step. I'd be grateful for anyone who could take a look. :) Thanks.
I think your method and arithmetic is OK.
Check if you should add the radius of the wheel to the head.
looks ok to me
Ah that's a good suggestion. Looking at the context and previous questions of the textbook though I don't think I need to. Thanks. :)
9K
29K
