Maximum force on stacked boxes, when we don't want the boxes to slip.
The discussion revolves around calculating the maximum force that can be exerted on stacked boxes without causing them to slip. The weights of the boxes are M1 = 3 kg and M2 = 4 kg, with static and kinetic friction coefficients provided. Initial calculations for maximum static friction between the boxes yielded 23.52 N, but the correct maximum force is 36.6 N. The solution involves considering both the frictional forces and the acceleration of the boxes, leading to a more complex relationship between the applied force, friction, and the resulting tension in the connecting string. The final calculations clarify the dynamics of the system, ensuring the boxes remain stationary relative to each other.
tomas123
There are two blocks stacked on top of each other. M2 is on top of M1. M1 = 3 kg. m2 = 4 kg. μs between the two boxes = 0.6. μk between m2 and the floor = 0.2.
Using a rope, we exert a force T on m2, dragging both boxes 5m. What is the maximum force we can exert on m2, if we don't want m2 to slip on m1.
Fk = μk * n
Fs(max) = μs * n
I found Fs(max) between m2 and m1.
Fs(max) = n * μs =
mg * 0.6 =
4kg * 9.8 * 0.6 =
23.52 N.
1 problem! the solution is 36.6 N
Sometimes it's helpful to recast the problem into a form that you've seen before, or at least one that makes the interrelationships between the forces more obvious.
Presumably you've calculated the frictional force that the floor exerts upon the bottom box when that box is moving. Call it F1. What's its derivation and value?
Also presumably you've calculated the maximum static frictional force that can be withstood between the boxes before they will slide. Call that F2. What's its derivation and value?
Now redraw the problem placing the boxes separately on the "floor". Connect them with the proverbial "light inextensible string". The tension in that string will represent the frictional force operating between the boxes; If it ever exceeds F2 then the string will snap and the boxes will become unconnected (In the original configuration, they would start to slide).
The first box, M1 has frictional force F1 retarding it and some tension T in the string pulling it forward. The second box M2 has no friction with the floor, but has tension T retarding it and the force of the rope pulling it forward. Can you find an expression for the tension in the connecting string in terms of the force applied by the rope?
I get:
max tension = F2 = 23.52 N
Friction F1 = μk * n = 0.2 * 9.8 *7 = 13.72
tension on string = sum of forces on string = F2 - F1 = 37.24 N
The answer is supposed to be 36.6 N. What did I do wrong?
I really appreciate the help!
tomas123 said:
I get:
Okay, good so far!
Oops. The frictional forces are not the only ones acting. Unless the applied force is specifically metered to keep the blocks moving at a constant velocity, there will be acceleration and thus inertial forces (m*a) involved for each block. The expression for the tension will be just a bit more complicated because of this.
For the moment, concentrate on box M1 which is being pulled by the string and retarded by friction. If the acceleration of the block is a, what must the tension in the string be?
aah I get it!
the sum of F on M1 is 9.8N. Divided by 3kg = 3.267 m/s2.
Sum of F on whole system = force by rope - friction
(7kg * 3.267 m/s2) +13.72 = force by rope
36.589 = force by rope
Thank you!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
