Maxwell stress tensor in electrodynamics
The discussion focuses on the Maxwell stress tensor in electrodynamics, specifically the relationship between dyadic products of electric and magnetic fields. Participants clarify that the equality \{\vec{E},\vec{D}\} = \{\vec{D},\vec{E}\} holds when the permittivity and permeability tensors are symmetric. The notation used for dyadics is debated, with some preferring a simpler representation. The implications of symmetry in the tensors for deriving the Maxwell stress tensor are also explored, emphasizing the need for a consistent notation to avoid confusion. Overall, the conversation highlights the mathematical intricacies involved in electrodynamics.
Petar Mali
\hat{N}=\{\vec{E},\vec{D}\}+\{\vec{H},\vec{B}\}-\frac{1}{2}(\vec{D}\cdot\vec{E}+\vec{B}\cdot\vec{H})\hat{1}
\hat{1} - unit tensor
If I look \{\vec{E},\vec{D}\}. I know that
\{\vec{E},\vec{D}\}=\{\vec{D},\vec{E}\}^*
But when I can say that
\{\vec{E},\vec{D}\}=\{\vec{D},\vec{E}\}?
and when can I say that
\{\vec{H},\vec{B}\}=\{\vec{B},\vec{H}\}?
Thanks for your answer.
Just to remind you
definition
\{\vec{A},\vec{B}\}\cdot \vec{C}=\vec{A}(\vec{B}\cdot \vec{C})
\vec{C}\cdot \{\vec{A},\vec{B}\}=(\vec{C}\cdot\vec{A})\vec{B}
Any idea?
Just to remind you
definition
You seem to be using dyadics, which is fine with me, but I am not familiar with your notation
I just use \vec{E}\vec{D}
I don't know what your star notation means. Star usually means cc,
but you seem to be using it as matrix transpose.
\{\vec{E},\vec{D}\ is not equal to
\{\vec{D},\vec{E}\} for two general vectors, but the derivation of the MST requires that epsilon and mu be symmetric.
In this case, the equality holds.
I like more
\{\vec{E},\vec{D}\}
for example
\nabla\cdot \{\vec{E},\vec{D}\}
You write this like
\nabla\cdot(\vec{E}\vec{D})
Is that true?
This is OK but people sometimes forget \cdot and that can make confusion!
How can I show that \hat{\epsilon} and \hat{\mu} must be symmetrical in that case? Are you sure?
Petar Mali said:
I like more
\{\vec{E},\vec{D}\}
for example
You write this like
Is that true?
What is this operator?
\{\vec{E},\vec{D}\}
In the derivation of the MST, one step is to show that grad(D.E) with D held constant is equal to (1/2)grad(D.E). This requires that epsilon_ij be symmetric and constant.
By the way, in physics, {D,E} is used to denote the anticommutator.
That is why I use DE.
Well \{,\} is also in some books symbol for Poisson bracket, and somewhere people use [,]_{PB}
For anticommutator you can use symbol
[,]_{+}.
Now for your answer
It's used that
(\vec{D}\cdot \nabla)\vec{E}+\vec{D}\times rot\vec{E}=\nabla(\frac{1}{2}\vec{D}\cdot \vec{E})=\nabla \cdot (\frac{1}{2}(\vec{D}\cdot \vec{E})\hat{1})
If \hat{\epsilon} and \hat{\mu} are symmetric. They can be time functions? Right?
Using that I get
<br /> \hat{N}=\{\vec{E},\vec{D}\}+\{\vec{H},\vec{B}\}-\frac{1}{2}(\vec{D}\cdot\vec{E}+\vec{B}\cdot\vec{H })\hat{1}<br />
\nabla(\vec{a}\cdot \vec{b})=\nabla(\vec{a}^*\cdot \vec{b})+\nabla(\vec{a}\cdot \vec{b}^*)
If \vec{b}=\hat{\alpha}\vec{a}
\hat{\alpha} -symmetric tensor
\vec{a}^*\cdot\vec{b}=\vec{a}^*\cdot \hat{\alpha}\vec{a}=\vec{a}\cdot \hat{\alpha} \vec{a}^*
\vec{a} \cdot \vec{b}^*=\vec{a} \cdot \hat{\alpha}\vec{a}^*
So
\nabla(\vec{a}\cdot \vec{b})=2\nabla(\vec{a}\cdot \vec{b}^*)
\vec{a}\times rot\vec{b}^*=\vec{a}\times (\nabla \times \vec{b}^*)=\nabla(\vec{a}\cdot \vec{b}^*)-(\vec{a}\cdot \nabla)\vec{b}^*
so
(\vec{a}\cdot \nabla)\vec{b}+\vec{a} \times rot\vec{b}=\frac{1}{2}\nabla(\vec{a}\cdot \vec{b})
Thanks for your answer!
