What is the significance of the charge density in Gauss's law?
  • Context: Graduate
  • Thread starter Thread starter maxbashi
    Gauss's law Law
The discussion centers around the significance of charge density in Gauss's law, particularly in the context of transitioning from the integral form to the differential form of the law. Participants explore the implications of charge density being defined at every point in space rather than as an average over a volume.
  • One participant notes the transition from the integral form of Gauss's law to the differential form, questioning the meaning of charge density (ρ) as it appears in the latter.
  • Another participant provides a link to additional resources and explains that the enclosed charge (Q_enc) can be expressed as a volume integral of the charge density ρ(r) within the surface integral.
  • A participant clarifies that charge density is defined at every point and is not an average, comparing it to mass density, which can also vary within a volume.
  • There is a discussion about the mathematical representation of charge density as a limit taken at a point, emphasizing its definition in terms of a small volume element.
  • A participant inquires about the method for calculating the enclosed charge (q) using the triple integral of charge density (p) over volume (dV).
  • Another participant confirms that the proposed method of using the triple integral to find the enclosed charge is correct.
Participants generally agree on the definition of charge density and its significance in Gauss's law, but there are varying levels of understanding regarding its implications and the mathematical methods for calculating enclosed charge. The discussion remains exploratory with no consensus on all aspects.
Participants express uncertainty about the implications of charge density and its relationship to other mathematical concepts, such as the Laplacian, which has not yet been covered in their studies.
maxbashi
So I'm reading Div, Grad, Curl and All That which is my only exposure to Maxwell's equations. The author started with the integral form of Gauss's law (which I get), where the surface integral of the electric field = the enclosed charge (q) divided by epsilon nought. But in deriving the differential form using the divergence theorem, q becomes the volume times the average charge density (p), but in the final equation (of the differential form) is says the divergence of the electric field equals the charge density (not average) divided by epsilon nought.
Getting to my point, what is the meaning of the charge density in the differential form? If it's not an average, it must vary at the different points in the volume you're considering... so I'm not sure what the p means here. If I'm not being clear please let me know and I'll try to explain it better. Thanks
Does this help? :
https://www.physicsforums.com/library.php?do=view_item&itemid=2
[tex] <br /> \vec{E}=\lim_{q\rightarrow 0}\frac{\vec{F_e}}{q}<br /> =\frac{1}{4\pi \epsilon_o}\int\frac{\rho (r)}{r^2}\hat{r}d\tau[/tex]
[tex] \oint \vec{E}\cdot d\vec{a} =\frac{Q_{enc}}{\epsilon_0}[/tex]
Qenc is the volume integral of the charge density ρ(r) in the volume enclosed by the surface integral on the left hand side
Bob S
I think you stated it correctly right here. The charge density is a property that is defined at every point, and it is not an average over a volume. You can think of it as similar to mass density. You can have a material where the mass density is not constant over a volume. Every point has a different value in general. It is similar to a scalar variable as a function of position, but strictly speaking it is not a scalar because it does not transform like a scalar with coordinate transformations. This last statement is more that you need and will likely confuse you a little, so ignore it for now, but store that information away for later use because it does become important later in your studies.
In case it is still not clear, think of [tex]\rho[/tex] as a limit taken at a point. Consider a small volume element [tex]\Delta V[/tex] containing charge [tex]\Delta Q[/tex]. The charge density is then approximately [tex]\rho\approx{{\Delta Q}\over{\Delta V}}[/tex]. Now take the limit as volume goes to zero and you have charge density precisely.
[tex]\rho=lim_{\Delta V \rightarrow 0}{{\Delta Q}\over{\Delta V}}[/tex]
Okay so that part is making sense. So from skimming ahead it looks like actually finding the charge has something to do with the laplacian (which I haven't gotten to yet), but could you get the enclosed charge (q) by taking the triple integral of p dV? Or would you just use some other method?
maxbashi said:
... but could you get the enclosed charge (q) by taking the triple integral of p dV?
Yep, it sounds like you get it.
  • · Replies 83 ·
  • · Replies 29 ·
