Meaning of the square root and its contradiction
The discussion centers on the definition and properties of the square root function, particularly in relation to complex numbers. It highlights that the square root function should be defined from the complex numbers to the complex numbers, as it is not single-valued in this context. The contradiction arises from the misunderstanding that \(\sqrt{x^2} = |x|\) holds for complex numbers, which it does not. Instead, the correct relationship involves the modulus, expressed as \(|x| = \sqrt{x \bar{x}}\). The conversation emphasizes the need to adapt definitions when extending concepts from real to complex numbers.
kntsy
Is square root a function in this way?
f:\mathbb C\rightarrow\mathbb R^+
However contradiction can be drawn:\sqrt{x^2}=|x|\text{ and } i^2=-1
\sqrt{-1}=\sqrt{i^2}=|i|=1
\sqrt{-1}=1 ??What is the problem in the definition or the deduction?
Mathematics news on Phys.org
No, it's not- the square root function is from \mathbb C to \mathbb C. And functions, on the complex numbers, are not in general "single valued".
\sqrt{-1}=1 ??
The problem is with your definition, which is wrong.
That's a quite narrow view. It might not be the most mathematically useful way, but you might as well define Sqrt to be the principal value. Just as some people use Ln() instead of ln(). This makes writing out equations much easier because you have actual functions.
In this case the answer to the question is
\sqrt{x^2}\neq |x|
for complex numbers!
What does it mean for function not being single-valued? Does it violate the definition of function?
\sqrt{x^2}\neq |x|
Is it due to the definition of absolute value on complex number?
I suppose you could say that. A very important identity for complex numbers is x \bar{ x } = | x |^2, so the correct identity relating square roots and absolute value (usually called modulus when extended to complex numbers) is | x | = \sqrt{ x \bar{ x } }. The reason that you're familiar with the identity | x | = \sqrt{ x^2 } for real numbers is that for a real number x, x=\bar{x}, so x\bar{x}=x^2.
The definition of "function" for real numbers requires that f(a) be a unique number. To use Gerunuk's phrase, that is too "narrow" a view for complex numbers.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
