Measurement standard for joules = Momentum in kilograms
The discussion revolves around the calculation of momentum for a photon using its energy derived from frequency. Participants explore the appropriate equations and units for momentum, specifically seeking clarification on the measurement in kilogram-meters per second.
  • One participant calculates the energy of a photon using its frequency and attempts to find momentum using the equation p=E/c, questioning the units of momentum.
  • Several participants inquire about the units of energy and momentum, emphasizing the importance of using consistent SI units.
  • Concerns are raised about the significant figures in the calculations, with suggestions that the precision of the results should match the precision of the input values.
  • Another participant checks the wavelength corresponding to the given frequency, noting discrepancies in classification as x-ray or ultraviolet light.
  • There is a discussion about the formula used to calculate energy (E = hf) and the necessity of including units in calculations to avoid confusion.
  • One participant expresses uncertainty about the energy value derived and seeks clarification on how to convert wavelength from nanometers to meters for calculations.
  • Another participant corrects a previous misclassification of the wavelength as x-ray, acknowledging the error and providing the correct classification.
  • Participants discuss the calculation of energy using Planck's constant and the frequency, with one participant confirming their method and result.
Participants do not reach a consensus on the correctness of the energy value calculated or the classification of the wavelength. Multiple competing views remain regarding the significance of units and significant figures in the calculations.
There are unresolved questions regarding the proper application of formulas and the accuracy of the energy value derived from the frequency. The discussion highlights the importance of unit consistency and significant figures in scientific calculations.
This discussion may be useful for individuals interested in the principles of photon energy, momentum calculations, and the importance of unit consistency in physics.
Camdenl
Basically, I found the energy of a photon using its frequency ((6.8*10^15) and E=(3.6496394*10^-16)) and so I then used "p=E/c" to find the momentum and got 1.2173887*10^-24 however I don't know the measurement of the momentum. Is there a better equation to use to find momentum, and what would the measurements be?
(edit) I'd like to know the momentum in kilogram-meters per second.
Hi Camden, :welcome:
What are the units of the E you found ? And what are then the units of p if you use c = 3 108 m/s a (as it seems you do) ?
And, eh, if you have 2 digits of ##f##, you should end up with 2 (perhaps 3) digits of p, not 8
The "E" was in joules, and I would like to find out the momentum "p" in kilogram-meter per second.
Two things:
1. Pay attention to significant figures! It is meaningless to write all those numbers up to 7 decimal places.
2. If you keep all your units in SI (i.e. energy in Joules, c in m/s), then your momentum will also be in SI units that you are looking for. Remember that "Joules" is equal to kg.m2/s2.
Zz.
So, Camden, is it clear to you now that you had p in the units you wanted all along ?
First, just out of curiosity I checked the wavelength. This is 44 nm, a pretty hard x-ray. That's fine, I just thought I'd check and make sure that is what you intended.
You say you took this frequency and found the energy. How? E = h f. These aren't just numbers. E has units. h has units. f has units. You could use completely different units for h and get a completely different number for E. The numbers would mean the same energy if they are written with their units. Completely different numbers meaning the same thing with units should underscore the point that the numbers don't mean anything without units. You must use units.
So I'm looking for the units you might have used for h. In SI units of J-s h is 6.626E-34.
6.8E15 / s * 6.626E-34 J - s = 4.5E-18 J
So your energy doesn't seem to be Joules. In fact I don't see any obvious choice of units for h that would produce your number. Where did that energy number come from?
So a J = kg m^2 / s^2
E / c = p so
(4.5E-18 kg m^2 / s^2) / ( 2.997E8 m/s) = 1.5E-26 kg m/s
in the units you requested
[oh boy, it didn't occur to me to check if Camden computed ##h\nu## properly ... kudos CK!]
ZapperZ said:
Two things:
Zz.
The numbers don't have 7 decimal spots, they have 24, they're shortened. For example, 1.2173887*10^-24 is equal to 0.000000000000000012173887. The whole thing's a decimal.
E / c = p so
Thanks, I'm fairly new to stuff like this since I'm learning out of personal interest.
Since you are doing your own personal lesson, I suggest you look up the meaning of "significant figures".
Zz.
Zz.
Oh, I got it, I just didn't understand. I'm pretty new to this stuff, sorry
I'm sorry, but I checked for 44 nm on a wavelength chart, and it came under uv light. Did I make some mistake, or what?
Wavelength is fine: C = 3 10 8 m/s divided by frequency 6.8 1015 1/s gives 4.4 10-8 m or 44 nm.
An a chart like this ranges it as far uv, very soft x-ray.
(Same chart shows an energy between 10 and 100 eV)
Now we would like to now how you found your E :
did you use a formula ? which ?
I adopted the frequency from "http://www.csun.edu/~jte35633/worksheets/Chemistry/5-2PlancksEq.pdf" and then attempted to use the formula available on that site. The probable reason for why I got my E would likely be because of my novice in this subject. Also, could you explain to me how I could use nm and convert it so I could use it in an equation?
Ok, I see the frequency 6.8 1015 1/s in question 1. They give ##\ h## = 6.63 10-34 J s .
What do you get when you apply ##\ E=h\nu\ ## ?
Nanometers are 10-9 m. So 4.4 10-8 m / 10-9 (m/nm) = 44 nm.
And conversely: wavelength in nm x 10-9 (m/nm) = wavelength in m
Ah, yes. I was completely off base calling that X-ray. My typing out ran my brain. My apologies.
So I grabbed Plancks constant for joules(6.626070040(81)×10^−34) and multiplied it by the frequency(6.8×10^15) using the google calculator it came out at 3.6496394e-16. Also, thanks for the info on nanometers.
If you multiply 6.8 times 6.6, what do you get? If you subtract 15 from 34, what do you get?
Always do the easy sanity checks.
Ok, thanks.
The google calculator (in my case I just type it in on the search bar) tells you what it does to calculate the result:
6.626070040 * (81) * (10^−(34)) * 6.8 * (10^15) just above the 'result' 3.6496394e-16​
6.626×10^−34 * 6.8×10^15 works a lot better: 4.50568e-18​
So it uses e notation for the result. Funny enough it doesn't like same notation for input
6.626e−34 * 6.8e15 is read as (6.626 * e) − (34 * 6.8e15) = -2.312e+17​
And I (seasoned Fortran programmer) found no way to enter a negative exponent of 10 using this e notation. (anyone ?)
Someone should tell those guys to clean up their act. School kids (and lots of others) blindly copy the nonsensical result !
Thanks for the info!
  • · Replies 138 ·
10K
  • · Replies 0 ·
  • · Replies 94 ·
