Measuring Entangled Particles in two different Basis
8 replies · 2K views
randomuser3210
Consider two entangled spin half particles given by the generic form of Bell Equation in Z-axis:
##\psi = (a\uparrow \uparrow + b\downarrow \downarrow)## where ##a^2+b^2=1##
In a (2D) planer rotated (by an angle ##\theta##) direction the new equation can be given by:
##|\psi \rangle = [\alpha \cos^2(\theta/2) + \beta \sin^2(\theta/2)] |\uparrow_a\uparrow \rangle + ##
##[(\alpha \sin^2 \theta/2 + \beta \cos^2 \theta/2)] |\downarrow\downarrow \rangle ##
##[(\beta-\alpha) \cos(\theta/2) \sin(\theta/2)] (|\uparrow\uparrow \rangle +|\uparrow\downarrow \rangle +##
Now Alice keeps one particle and sends the other to Bob. Here is the Q:
1. Suppose, Alice measures the particle in ##theta## direction. Then after that, Bob measures in the Z direction. What is the probability of Bob getting the particle ##\uparrow## and ##\downarrow## in Z direction.
I know that as soon as Alice measures the particle in ##\theta## direction, the entanglement collapses. So we can measure the probability by using wave function. But, can someone help with the cases for 'cross measurement' i.e. as above?
Let ##|\sigma_{\theta} \rangle## and ##|\sigma_z \rangle## be the eigenvectors of the spin component in ##\theta## and ##z## direction respectively. Then the probability that A meausures the value ##\sigma_{\theta}## on her spin and B ##\sigma_z## on his, is given by
$$P(\sigma_{\theta},\sigma_z)=|\langle \sigma_{\theta},\sigma_z|\psi \rangle|^2.$$
You only need to express everything in a common basis (I've given all this in a thread some days in this forums, so you can just copy it from there).
Thank you. I don't have background in QM/Physics. So I am lost at this compact reply and notation. If possible at all, could you provide more explicit probabilities (in notations in OP). Or point to a resource that goes step by step..
It doesn't matter who measures first. Bob's measurement has a probability ##|a|^2## or ##|b|^2## to be up or down. If Bob's outcome is up (or down), then the probability that Alice's measurement is up is ##\cos^2 \frac \theta 2## (or ##\sin^2 \frac \theta 2##). That gives the four probabilities:
$$p(\uparrow_A \uparrow_B) = |a|^2\cos^2 \frac \theta 2; \ \ p(\downarrow_A \uparrow_B) = |a|^2\sin^2 \frac \theta 2; \ \ p(\uparrow_A \downarrow_B) = |b|^2\sin^2 \frac \theta 2; \ \ p(\downarrow_A \downarrow_B) = |b|^2\cos^2 \frac \theta 2$$
So if I understand correctly, no matter who measures in what direction first (in any of the 4 General Bell States, not just this one), the end result of the measurement of Bob (and the probabilities of ##\downarrow_B or \uparrow_B## only depends on the direction Bob measures in.
The arguments of the cos and sin factors must be ##\theta/2##:
Let's calculate everything in the ##\sigma_z##-eigenbasis, ##|\pm 1/2 \rangle##. For the single spins you have the eigenvectors for the spin components in ##\theta##-direction
$$|1/2_{\theta} \rangle=\cos(\theta/2) |1/2 \rangle + \sin(\theta/2)|-1/2 \rangle$$
$$|-1/2_{\theta} \rangle=-\sin(\theta/2) |1/2 \rangle +\cos(\theta/2) |-1/2 \rangle.$$
With
$$|\Psi \rangle=\alpha |1/2,1/2 \rangle + \beta|-1/2,-1/2 \rangle$$
we need the following scalar products
$$\langle 1/2_{\theta},1/2|\Psi \rangle=\alpha \cos(\theta/2), \quad \langle 1/2_{\theta},-1/2|\Psi \rangle = \beta \sin(\theta/2), \quad \langle -1/2_{\theta},1/2|\Psi \rangle=-\alpha \sin(\theta/2), \quad \langle -1/2_{\theta},-1/2|\Psi \rangle = \beta \cos(\theta/2).$$
The probabilities are the moduli squared:
$$P(1/2_{\theta},1/2)=|\alpha|^2 \cos^2(\theta/2), \quad P(1/2_{\theta},-1/2)=|\beta|^2 \sin^2(\theta/2), \quad P(-1/2_{\theta},1/2)=|\alpha|^2 \sin^2(\theta/2), \quad P(-1/2_{\theta},-1/2)=|\beta^2|\cos^2(\theta/2).$$
Yes. You can always think of it as a simultaneous measurement. Bob's results are the same statistically whatever Alice does; and vice versa.
PS another way to see this is to express the state as a tensor product, using different bases for the constituent particles:
$$\psi = a \uparrow \uparrow + b \downarrow \downarrow = a \uparrow \otimes (\cos \frac \theta 2 \uparrow_{\theta} - \sin \frac \theta 2 \downarrow_{\theta}) + b \downarrow \otimes (\sin \frac \theta 2 \uparrow_{\theta} + \cos \frac \theta 2 \downarrow_{\theta})$$ $$ = a \cos \frac \theta 2 (\uparrow \otimes \uparrow_{\theta}) - a \sin \frac \theta 2 (\uparrow \otimes \downarrow_{\theta}) + b\sin \frac \theta 2 ( \downarrow \otimes \uparrow_{\theta}) + b \cos \frac \theta 2 (\downarrow \otimes \downarrow_{\theta})$$
And then you can just read off the amplitudes.
  • Wow
