Measuring the speed of light on moving systems
  • Context: High School
  • Thread starter Thread starter CHAIM123
    Light Speed
The discussion centers on measuring the speed of light from a moving spaceship, particularly in relation to light sources it approaches and moves away from. It explores concepts from special relativity, including the constancy of the speed of light and the implications of relative motion.
  • Some participants question the meaning of "in relation to" in the context of measuring light speed from a moving spaceship.
  • One participant asserts that the speed of light is constant and that time dilation occurs at high speeds, leading to confusion about measuring light speed when moving away from a source.
  • Another participant emphasizes the importance of the second postulate of relativity, which states that light's speed is invariant in all inertial frames.
  • Some participants argue that all motion is relative, and thus there is no absolute state of motion for the spaceship or the Earth.
  • There is a discussion about the inadequacy of describing time dilation simply as "time running slower," with participants noting that each observer measures the other's clock as ticking slowly.
  • One participant introduces a comparison to the speed of sound, questioning if it could serve as a second postulate of relativity, but others clarify that sound speed is dependent on the medium and not frame invariant.
Participants express differing views on the implications of relativity, particularly regarding time dilation and the constancy of light speed. There is no consensus on the interpretation of these concepts, and multiple competing views remain present in the discussion.
Some participants express uncertainty about the translation of concepts and their understanding of relativity, indicating a potential limitation in the clarity of communication. The discussion also highlights the complexity of distinguishing between special and general relativity.
CHAIM123
A spaceship moves at half the speed of light, what will be the results of measuring the speed of light for it: in relation to the light source it is approaching and in relation to the light source from which it is moving away?
What do you mean by "in relation to"? And what does the second postulate of relativity say?
If I'm not understood it's because I have to translate into English. I'm sorry.
I learned that the speed of light is always constant, and if I move at half the speed of light then time is slower, so I can't measure the speed of light as higher. The question is in relation to the light coming from a light source from which I move away, is the speed measured constant even then?
I apologize for my ignorance... I'm barely a beginner...
The answer to your question is the second postulate if relativity. Can you quote it?
This is half of the story, which may be confusing you. You also need to take into account the relativity of simultaneity.
Thank you !!!
I started reading about the subject. It will take me a long time to figure it out...
There is no such thing as "moving at half the speed of light". All motion is relative. You must be moving at half the speed of light relative to something. There is also no such thing as "time running slower".
Consider these two scenarios, which are physically equivalent:
You are on Earth and a spacecraft is moving towards the Earth at half the speed of light. Note that this means the Earth is moving towards the spacecraft at half the speed of light.
You emit a light signal towards the spacecraft. Both you and the spacecraft measure the speed of that light signal as ##c##.
The spacecraft emits a light signal towards Earth. Both you and the spacecraft measure the speed of that light signal as ##c##.
In relativity, there is no physical difference between the Earth and spacecraft in this scenario. There is no sense in which the spacecraft is "really" moving or the Earth is "really" moving. The motion is relative.
Isn't time slower in a body that is in fast motion or when the density of matter in its environment is high?
No. If you are in inertial motion moving fast relative to me then in my rest frame I will measure your clocks to be ticking slowly. But you will measure my clocks to be ticking slowly. So "time runs slowly" is an inadequate description.
"Time runs slowly" is always a terrible description. But with some very large caveats, it's less terrible in this context. Clocks at lower gravitational potential will tick slower than those at high potential.
There is no such thing as "a body in fast motion".
It's best to leave gravitation (general relativity) until you understand special relativity (no gravity).
Yes. In your rest-frame, the source is moving away from you.
As others mentioned, see the two postulates of SR:
Wikipedia said:
1. First postulate (principle of relativity)
The laws of physics take the same form in all inertial frames of reference.​
2. Second postulate (invariance of c)
As measured in any inertial frame of reference, light is always propagated in empty space with a definite velocity c that is independent of the state of motion of the emitting body. Or: the speed of light in free space has the same value c in all inertial frames of reference.​
Source:
https://en.wikipedia.org/wiki/Postulates_of_special_relativity
From the definition of an inertial standard coordinate system, the assumption, that the transformation must be linear and those two postulates follows the Lorentz transformation:
https://en.wikipedia.org/wiki/Lorentz_transformation
Sorry, what if we take the constancy of the speed of the sound as second postulate of special relativity ? As far I know the speed of the sound is independent from the motion of the source as well.
  • Skeptical
It's dependent on the speed of the medium, though, so it isn't frame invariant and doesn't lead to relativity.
So consider the following scenario: let's take an inertial frame in which the medium is at rest and source in moving with a given velocity. The measured speed of sound in this inertial frame will be let me say ##s## regardless of the motion of the source.
Now switch to another inertial frame (where the source and the medium are moving): in this inertial frame the measured speed of sound will be independent from the motion of the source as well, however it will be different from ##s##, hence it is not frame invariant.
  • · Replies 72 ·
  • · Replies 33 ·
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 24 ·
  • · Replies 93 ·
