Mechanical Physics: Coefficient of Friction
In summary: I would think that the vector would be pulled rather than pushed when considering the vector as it applies the force.Ohh, so when you say "at an angle of 30o below the horizontal", what you mean is "downward from the horizontal" ?Yes, downward from the horizontal.
Daniel Guh
A force of 300 N is applied to a 20 kg crate at an angle of 30o below the horizontal. Determine the acceleration of the crate as it moves along the horizontal surface. The coefficient of friction between the crate and the surface µk is 0.50.
1. 17.2
2. 8.6 (My choice but it's incorrect)
3. 4.3
4. 9.8
Fg = mg
μ = Ff / Fn
F = ma
First of all, the pulling force is
300N cos(30) = 260 N
At this point, I try to find the friction force
Fn = mg = 20kg * 9.81 m/s^2 = 196.2 N
Then,
Ff = μ * Fn = 0.5 * 196.2 N = 98.1 N
So after canceling the horizontal forces,
260N - 98.1N = 161.9N
And the acceleration will be 161.9N / 20kg = 8.1 m/s ^2
Since 8.6 is the closest I choose 8.6, but it's incorrect.
The normal force is not mg in this case
Ohh, do I have to include the force from the 300N? Since there is a downward force, the normal force will be greater?
Likes hutchphd
Yes. Let's say you have a book lying on a table. If you push down on the book with your hand, the normal force from the table on the book will be greater than ##m_\text{book}g##.
Likes mathguy_1995, Daniel Guh and MatinSAR
@Daniel Guh Can you draw a free body diagram?
Note that ##\vec F_{net}=m\vec a## is equivalent to three component equations:
##F_{net,x}=ma_x##
##F_{net,y}=ma_y##
##F_{net,z}=ma_z##
If there is no motion in z direction it means that ##a_z## is ##0## so we should have ##F_{net,z}=0## .
Consider again the normal force. Part of the force ##F## and particularly its component ##F\cdot \sin (30)## participates into that computation. As said above, if someone pushes downwards a book (placed on a table), the normal force will not be equal to its weight, but greater, otherwise, the book could've not stood on it.
Likes Daniel Guh
Welcome, @Daniel Guh !
May be I am wrong, but to me, the statement “A force of 300 N is applied to a 20 kg crate at an angle of 30o below the horizontal.” does not mean downward.
To me, "above" and "below" the horizontal are synonymous with above the horizon and below the horizon. The sun rises above the horizon and sets below the horizon. The reference point is at the horizon. So if you have a vector below the horizontal, this conveys (at least to me) that the tail of the vector is at the horizontal and its tip below the horizontal. If this force vector were parallel to the position vector of the Sun relative to the horizon, it would describe the Sun at dusk.
Likes MatinSAR
That's also how I read it ...however the answer for that is not in the list.
It would have been so easy to phrase it like "A force of 300N is applied downwards, 30deg from the horizontal" or summat.
Then, how would you understand this statement?
Not sure which way you say you would read it. In my experience the terminology is fairly standard. It is below the horizontal from the perspective of whatever is applying the force, so tending downward
And it does give me an answer in the list.
Likes hutchphd, MatinSAR and nasu
Whereas, treating it as an upward force does not... which is what I said.
But, the question does look unambiguously as if an upwards force is being applied, despite usage of "at" rather than "from" or "to".
If one were the applier of a downwards(ish) force, the obvious place to push would be the top of the crate and the obvious measurement for the angle would be from horizontal *upwards*. Why would you break open the crate and take the measurement there ?
Who said anything about breaking the box? You can push on top of the crate at any angle you want, above, below or along the horizontal.
Because you are thinking of it in regards to drawing a FBD, maybe, not from the perspective of the person, or whatever, applying the force.
How would you aim a rod if told to point it below the horizontal?
If not downward, the only alternative is upward.
I see @kuruman point of view, considering tail of the vector attached to the box, or it always being pulled rather than pushed.
Again, I may be wrong, but in practical terms, one pushes a box down-forward and pulls it up-forward.
Sorry about creating more confusion, @Daniel Guh
The statement does not mention either pulling or pushing. The force "is applied".
Likes malawi_glenn
Consider pushing vs pulling a car. Are these two options charactrized by how the vertical force component is directed? Or is it something else.
Btw the original problem formulation just said that a force was appllied. No pulling or pushing was mentioned
Only because you are assuming you are taller than the box.
Likes MatinSAR and nasu
Forces in a FBD are assumed to act at the CoM and are drawn with their tails at the CoM to facilitate figuring out the angles needed to add them.
Whether a pushing as opposed to pulling force acts on the system is irrelevant to how one draws the arrow representing this force. Consider a block hanging from a sting and one being supported by a table. The appropriate force arrow is drawn the same and there is nothing to distinguish the "pulling" from the "pushing" force.
(Edited to add clarity)
Likes Lnewqban, MatinSAR and nasu
The wording of the problem might be confusing a bit. However, if you try a few combinations of calculation you will see the result should be smaller than your calculated one. This diagram presents the quiz probably better:
This is probably clear already.
What is the coefficient of friction?
The coefficient of friction is a measure of the resistance to motion between two surfaces in contact. It represents the ratio of the force required to move one surface over the other to the force pressing the two surfaces together.
How is the coefficient of friction calculated?
The coefficient of friction is calculated by dividing the force of friction by the force pressing the two surfaces together. It can also be determined by measuring the angle at which an object begins to slide down an inclined plane.
What factors affect the coefficient of friction?
The coefficient of friction is affected by the nature of the two surfaces in contact, the amount of force pressing the surfaces together, and the presence of any lubricants or contaminants between the surfaces.
Why is the coefficient of friction important?
The coefficient of friction is important because it helps us understand and predict the behavior of objects in contact. It is used in various applications, such as designing brakes for vehicles, determining the maximum load a surface can support, and improving the efficiency of machines.
How does the coefficient of friction relate to mechanical physics?
The coefficient of friction is a fundamental concept in mechanical physics, as it is essential in understanding the forces and motion involved in mechanical systems. It is used in various equations and principles, such as Newton's laws of motion and the work-energy theorem.
