Mechanical Time Dilation: Explained
akashdgr8
when the expression for time dilation was derived the clock assumed used the light signal to progress but the normal clocks which work using chemical energy or the stored potential energy in the spring must not be influenced with the relative velocity
can anyone explain me the mechanical reason for time dilation in ordinary clocks
First of all, welcome to the Forums!
There's no clock assumed in the derivation of the Lorentz Transformation (LT). Basically, time dilation is one component of a 4d transform that is the natural consequence of the constancy of the maximum speed (which also happens to be that of light).
Then, once people understood how time is affected by the LT, explanations were devise to try to make it clear, light-clocks were used only then.
It just depends on your notion of time, and what it effects. You have to consider, KE in not relative. to clear this up, it is though that ALL things tend to slow down at high velocity, because of the dilation in time. The truth is that we don't exactly know what time is, we just observe it like every thing else :)
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
