Mechanics - centre of mass lamina
The discussion focuses on calculating the center of mass of a uniform lamina with a mass per unit area of 0.12 grams/cm², shaped as a square with a side length of 80 cm, from which a triangular section has been removed. The coordinates of the square's corners are defined, and a particle of mass 0.5 kg is attached at corner C(80, 80). The solution involves applying the principle of superposition to find the center of mass by treating the removed triangle as having negative mass. This method effectively combines the mass distributions of the square, triangle, and attached particle.
  • Understanding of center of mass calculations
  • Familiarity with geometric shapes and their properties
  • Basic knowledge of mass distribution concepts
  • Ability to perform coordinate geometry calculations
  • Study the principles of superposition in physics
  • Learn how to calculate the center of mass for composite shapes
  • Explore the concept of negative mass in physics
  • Practice problems involving center of mass with varying mass distributions
Students and educators in physics, particularly those focusing on mechanics and center of mass calculations, as well as anyone involved in engineering or design requiring an understanding of mass distribution in physical systems.
kolomsg
hi, I'm stuck and I can't seem to find a simple solution to questions regarding how to find the centre of mass of a lamina.
for example:
A uniform lamina with mass/unit area 0.12grams/cm2 consists of a square of
side 80cm, with one corner at the origin O(0, 0) and other corners at B(80, 0),
C(80, 80) and D(0, 80). A triangle of material has been removed from one corner
by cutting a straight line from E(50, 0) to F(80, 40), and a particle of mass 0.5kg
is attached at C. Find the coordinates of the centre of mass.
If anyone could help me, that'd be much appreciated. thanks
Mathematics news on Phys.org
Welcome to PF!
Hi kolomsg! Welcome to PF! :smile:
Do you know how to find the coordinates of the centre of mass of several bodies, given that you know the coordinates of the centre of mass of each?
Apply that to the square, the triangle, and the particle, but with the triangle having negative mass! :wink:
hi, thanks a lot. it helped!
  • · Replies 31 ·
11K
