Mechanics: Dynamics (Newton's 2nd law)
The discussion centers on applying Newton's 2nd Law to a mechanics problem involving a 5 kg sphere and a 1 kg block connected by a rigid rod. Participants confirm that at the moment of release, the velocity is zero, leading to a normal acceleration of zero for the sphere. The focus is on determining the tension in the rod and the accelerations of both blocks using the equations of motion. The consensus is that Newton's 2nd Law is essential for solving the problem, rather than conservation of energy.
  • Understanding of Newton's 2nd Law of Motion
  • Basic principles of mechanics, including forces and accelerations
  • Knowledge of free-body diagrams
  • Familiarity with the concept of normal and tangential acceleration
  • Study the application of Newton's 2nd Law in multi-body systems
  • Learn how to construct and analyze free-body diagrams
  • Explore the relationship between tension and acceleration in connected objects
  • Investigate the differences between normal and tangential acceleration in mechanics
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone seeking to deepen their understanding of Newton's laws in practical applications.
Oblivion77
A sphere S with a mass of 5 kg is attached by a rigid rod to 1 kg block B which is free to slide with no friction in a horizontal slot. The system is released from rest. At the instant when it is released, find the tension in the rod and the accelerations of both blocks.
Sum of the forces in x = ma
Sum of the forces in y = ma
I am not exactly sure how to tackle this problem. Would I need to solve this using Newton's 2nd law? Or would this question require conservation of energy? Thanks.
Sorry wrong section
Well if you were to use conservation of energy, how would you relate the energy to the tension in the rod and the accelerations of the blocks?
That's true, I have another question then. Since the problem is asking "the instant it is released from rest" can you assume the velocity is 0 at that instant? Therefore the component of normal acceleration is 0?
Yeah, the velocity must be 0 at that instant (since it's at rest). But that can't possibly tell you anything about the acceleration at that instant; it's only if you knew the velocity at different times that you can use the velocity to find the acceleration.
(Consider the example of a pendulum; at the apex of the pendulum's swing the velocity of the pendulum is instantaneously zero, but it must be accelerating because the velocity increases a moment later as it starts swinging again).
You're going to have to crank out Newton's 2nd law I'm afraid.
I understand that I need to use Newton's 2nd law, but I am confused on the swinging of the pendulum. Plus it looks like I would need to take relative accelerations into account. Since the swinging of the sphere is moving with the block.
you don't need to worry about the pendulum effect, or relative accelerations, since it asks for the accelerations at the instant it is released. You know the normal acceleration of the sphere is 0, since V=0 at the instant it is released. Solve for tangential acceleration, and tensions, the acceleration of block b
  • · Replies 39 ·
  • · Replies 42 ·
  • · Replies 35 ·
