Mesh Analysis for time domains?
7 replies · 2K views · last reply
jisbon
Solve the following mesh circuit.
I've tried to solve the following circuit using mesh equation, but the solution seems to differ from my attempted answer.
Mesh circuit as follows:
Handwritten two-mesh circuit schematic with a 3 ohm resistor and a 2s inductor on the left loop, a 6s inductor, 2 ohm and 10 ohm resistors on the right loop, a 10 voltage source, and clockwise mesh current arrows.
My mesh equation is:
-10+3(i1)+2s(i1-i2)=0 (for the mesh on the left)
and
-10+12(i2)+6s(i2)+2s(i2-i1)=0 (right mesh)
However the answer seems to be different and claims that the equation are as follows:
Handwritten mesh analysis working: equation (3+2s)I1(s) + 2sI2(s) = 10 labelled 1, equation (12+8s)I2(s) + 2sI1(s) = 10 labelled 2, and I1(s) = (10 - (12+8s)I2(s))/2s.
Am I missing something here?
Thanks
You have to show us how you took the directions of currents ##I_1,I_2## to be
And why you say in time domain since it seems you doing it in the s-domain (Laplace transformed currents)?
Sorry, what I meant was s domain.
As shown in the diagram, I1 is in the clockwise direction, while I2 (the one on the right) is in anticlockwise.
Then in your equations you should put ##I_1+I_2## where you have ##I_1-I_2## (or ##I_2-I_1##) and then your answer is the same with the book answer.
You should put ##I_1+I_2## because that's what we get -given the current directions as you say -if we apply KCL at the junction with the 3##\Omega## resistor the 6s coil and the 2s coil ,
Sorry I now understood you use mesh currents, but still the total mesh current in the branch that has the source and the 2s coil is ##I_1+I_2## because one is clockwise and the other counterclockwise.
Oh I see. So if they are in the same direction, my old equations will then be correct?
This:
and
This:
and
Yes I believe the above equations are correct if both are anticlockwise.
I agree with Delta. You draw both of the currents in the same direction and so their sign should not flip.
