Mesh current method circuit problem with sign errors
4 replies · 3K views · last reply
orangeincup
Solve using the Mesh-current method. Determine the current magnitudes and the voltages across all elements
i=v/r
i1+i2+i3..=0
loop 1:
16(i3-3)+25i1-5i2=12
loop2:
4i1-5i2=15
1) i1=5/9i2-1
substituting 1) into loop2 gives
-25/9i2+5+16i2=-12
i2=1.1344
substituting i2=1.1233 into 1) gives i1=4.672
Can someone show me where I'm going wrong? I think I messed up the signs somewhere, I tried it a few ways and can't get it to satisfy KCL after I check my answer.
  • Circuit schematic labelled Figure 1: a 3 A current source and 16 ohm resistor on the left branch, 4 ohm and 1 ohm resistors on the top wire, a 5 ohm resistor in series with a 12 V source in the middle, and a 10 ohm resistor on the right with current i0 and voltage v0 marked.
That's impossible, because you have not sketched any loops or any currents ( except for i0 ).
You are the one to decide positive directions, etc.
My i1 is the middle loop (clockwise direction) and my i2 is the right loop (counter clockwise direction)
My i3 is the far left loop (clockwise direction) and the current was given as 3A
orangeincup said:
loop 1:
loop2:
4i1-5i2=15
Given the above I don't see how you arrived at your two loop equations. If i3 has a given value, why does the i3 variable appear in the Loop1 equation? Loop 2 has a total of 16 Ohms in it, yet I don't see where your equation accounts for i2 flowing through that, nor how i1 is flowing through 4 Ohms for that loop when I see that a 5 Ohm resistor borders the loops.
I think you need to redo your loop equations. In general it's usually beneficial to choose the same loop direction for all loops (one reason has to do with some really handy and time saving matrix solving methods that you'll learn about soon) Here's a diagram to help:
Circuit schematic with three mesh currents i1, i2 and a 3 A current source on the left; resistors 16 Ω, 4 Ω, 5 Ω, 1 Ω and 10 Ω, a 12 V source, and voltage v0 with current i0 labelled.
I suggest that as a first step you might eliminate the 3 A mesh by moving its effect into the i1 loop as a fixed voltage source (due to its flowing through the 16 Ohm resistor).
@orangeincup
Your i3 = 3A, simply because i3 is the only loop-current that passes the current-source.
As for i2-loop you will get ( according to figure in #4 ):
+12V - ( 5 + 1 + 10 )Ω * i2 - 5Ω( -i1 ) = 0 ( i1 has opposite direction as to i2 )
And the equation as for i1?
Now, solve the 3 equations ( your calculator can probably do that simultaniously), or substitute i3 = 3A ( leaving 2 equations ).
i16Ω upward = i1 - i3 and so on.
Calculate the voltages by ohm's law.
