How Does Grounding Affect the Electric Field of a Charged Plate?
In summary, the conversation discusses the setup of a point charge q held at a distance d from an infinite, grounded, conducting plate. The scalar potential above the plane is discussed, and it is concluded that the total induced charge on the plate is equal and opposite to the point charge. The question is raised about the electric field being zero at z=0 when the plate is negatively charged, and it is explained that the electric field inside a conductor is always zero, even with a net charge. The method of images is mentioned and it is clarified that the induced charge lies on the surface of the conductor. The questioner also asks about the counterpart of the negative charges when the positive charges are removed, but it is explained that the positive charges inside
  • #36
Niles said:
I don't know why, actually.. it struck me after I had posted. It's only if we place the grounded metal-stick on the side with the deficit of negative charges that additional negative charges are drawn from ground, since the atoms are fixed in the lattice.
Correct! For example, one can charge a conducting sphere using this method. If one places a conducting sphere with a grounding cable in an external electric field then the electrons will move to one side of the sphere and down the grounding cable (provided that the grounding cable is on the correct side) such that the area immediately around the grounding cable is electrically neutral. However, the side opposite the grounding cable with have a net positive charge. Now if the grounding cable is detached and the external electric field removed, then the sphere will have a deficit of electrons and hence will have gained a net positive charge.
  • #37
Drawing an electron from a grounded metal-stick is current. Current must obey Kirchoff's law (point charges in = point charges out).
Does ground really supply an electron to the plate? A capacitor has the same energy w/ or w/o a grounded plate. Is there an energy advantage to drawing an electron from ground?
  • Other Physics Topics
