MHB How Fast Do Carousel Rides Travel in Miles per Hour?
  • Thread starter Thread starter karush
    Per
Carousel rides can be calculated for speed in miles per hour using their radius and rotational speed. For a radius of 167 inches, the speed is approximately 2.4 miles per hour, while a radius of 231 inches yields about 3.3 miles per hour. The conversion factor of 2π radians per revolution is essential for aligning units correctly in these calculations. This ensures that the results remain consistent and accurate when converting between different measurement units. Understanding these unit conversions is crucial for solving similar problems effectively.
karush
MHB
the rides on a carousel are represented by $2$ circles with the same center with
$\displaystyle\omega=\frac{2.4 \text {rev}}{\text {min}}$
and the radius are:
$r_{13}=13 \text{ ft} 11 \text { in}= 167 \text { in}$
$r_{19}=19 \text{ ft} 3 \text { in}= 231 \text { in}$
find:
$\displaystyle\frac{\text {mi}}{\text {hr}}$ of $r_1$ and $r_2$
$\displaystyle v_{r13} =
167\text { in}
\cdot\frac{2.4 \text { rev}}{\text {min}}
\cdot\frac{2 \pi}{\text {rev}}
\cdot\frac{\text {ft}}{12\text { in}}
\cdot\frac{\text {mi}}{5280\text { ft}}
\cdot\frac{60 \text{ min}}{\text {hr}}
\approx
2.4\frac{\text{ mi}}{\text {hr}}
thus using the same $\displaystyle v_{r19}=3.3\frac{\text{ mi}}{\text {hr}}$
these ans seem reasonable but my question is on the
$\displaystyle\frac{2 \pi}{\text {rev}}$
isn't $\text {rev}$ really to the circumference of the circle
how ever if used the ans are way to large.
not sure why the $2\pi$ works.:cool:
Mathematics news on Phys.org
Re: miles per hour on a carousel
and the radius are:
find:
167\text { in}
\approx
It's all about the units, which you didn't include in your rev - rad conversion. 1 revolution = 2 pi radians. For a unit conversion it becomes the factor
[math]\frac{2 \pi ~ \text{rad}}{1 ~\text{rev}}[/math]
-Dan
so my eq should be this. but ans is them same?
\displaystyle v_{r13} = 167\text { in}
\cdot\frac{2 \pi\text{ rad}}{\text {rev}}
\approx 2.4\frac{\text{ mi}}{\text {hr}}
Yes, the number will be the same, but now the units line up. Keep the 2 pi rad = 1 rev in mind. You'll see it a lot in these kinds of problems.
-Dan
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
