Minimal mass from cosmological constant?
JollyJoker
I'm not sure in which forum this should go, but I hope this is close enough.
I recently realized that the lightest neutrino could be close in mass to the fourth root of the cosmological constant and found out I'm (unsurprisingly) not the first one to think of this after some googling. The first papers I found were somewhat interesting, but have few citations and their ideas seem to be ignored in most of the papers relating neutrino mass and cc.
http://arxiv.org/abs/gr-qc/0509110"
"Abstract: We show that in the framework of the classical general relativity the presence of a positive cosmological constant implies the existence of a minimal mass and of a minimal density in nature. These results rigorously follow from the generalized Buchdahl inequality in the presence of a cosmological constant. "
http://www.springerlink.com/content/u510l1mg85p963r1/"
"Abstract A lower bound for the mass of a rotating body is derived in the general relativity theory with positive cosmological term Λ. The bound suggests a neutrino rest mass ∼1 meV and a neutrino magnetic moment of 10−41 erg/gauss ∼ Planck's magnetic moment. A connection between gravity and electroweak interaction is suggested. "
Would anyone know if these conclusions would be obviously wrong, based on unfounded assumptions or otherwise invalid? An inequality showing that a given cosmological constant requires a minimum rotating mass, or even more interestingly the other way around; existence of a massive rotating particle forces the cosmological constant to be at most a given value, seems more than a little useful for explaining the low value of the cc.
One could even speculate that this would explain cosmic inflation if the neutrino masses didn't exist before electroweak symmetry breaking.
Any thoughts on this? Too good to be true? Just plain wrong?
I don't know that you can backtrack this beyond the Higgs Mechanism, i.e. before electroweak symmetry breaking. This strikes me as an artifact of the math relating to the general concept IMO.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
