Minimize Tension of Mass m Hanging from Cords
  • Thread starter Thread starter munchy35
    Tension
The discussion focuses on minimizing the tension in cord 2 of a system where a mass m hangs from two cords at specific angles. Participants suggest using a force diagram to analyze the problem, with one user opting for the component method to establish relationships between the tensions in the cords. The user proposes that to minimize tension in cord 2, the angle theta should be 0 degrees, which prompts a correction from another participant who advises against shortcuts and emphasizes proper elimination of variables. The conversation highlights the importance of deriving equations accurately and minimizing tension through systematic analysis. The key takeaway is to approach the problem methodically rather than making assumptions.
munchy35
A package of mass m hangs from a short cord that is tied to the wall via cord 1 and to the ceiling via cord 2. Cord 1 is at angle 40 degrees with the horizontal; cord 2 is at angle, theta.
a) for what value of theta is the tension in cord 2 minimized?
b)in terms of mg, what is the minimum tension in cord 2?
(here's the link of the problem with the picture http://www.unc.edu/~rowan/phys26/P26recit/p26-12-b.htm )
I know I have to figure out the force diagram first. I'm just having trouble with where to start.
I'm not asking for the solution, i just need some direction,
Hi munchy35! :wink:
You can solve this either with a vector triangle, or by taking components in a convenient direction.
Choose one method, and show us how far you get. :smile:
i used the component method so
for horizontal component i said t1cos40=t2cosx
(i'm just using x for theta)
t2=t1cos40/cosx
and t1 = t2cosx/cos40
so for part a, i used the t2 equation and just assumed for t2 to be a minimum cos x had to be maximum, the maximum cosx=1, so x= 0 degrees
^ can i just assume that?
for part b, i used vertical component
t1sin40 + t2sinx = mg
after plugging in t1
t2 = mg/ tan40cos0 + sin0
and eventually get 1.192mg
is that right
Hi munchy35! :smile:
munchy35 said:
… for horizontal component i said t1cos40=t2cosx
Nooo … stop trying to take short-cuts! :rolleyes:
Your two equations are correct :smile:
now eliminate t1 to find t2 …
then minimise t2. :wink:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
