Minimum Coefficient of static friction to keep a block from sliding?
To determine the minimum coefficient of static friction required to prevent a 5kg block from sliding on a 15kg block under a 40N horizontal force, the system must be analyzed for acceleration. Initially, the calculation incorrectly assumed the blocks would accelerate together, leading to a coefficient of 0.20. However, the correct approach involves recognizing that the frictional force must counteract the applied force, resulting in the equation (5kg)(2m/s^2) = μFN + 40N. After correcting the calculations, the minimum coefficient of static friction is found to be approximately 0.61. This highlights the importance of accurately accounting for all forces in friction-related problems.
Brodo17
A 5kg block is placed on top of a 15kg block that rests on a frictionless table. The surface between the top and bottom blocks is roughened so that there is no slipping between the blocks. A 40N horizontal force is applied to the top block. What is the minimum coefficient of static friction necessary to keep the top block from slipping on the bottom block?
F=ma
f=mew FN
Ok, in my first attempt I figured that if the blocks don't slide apart, then the entire sysstem would be accelerating. I said 40N = (20)a, and found that a=2m/s^2
Using this I said (5kg)(2m/s^2) = mew FN
10 / (9.8 X 5) = .20
However the answer says that it is actually .6
Then I though that maybe the system could not accelerate at all because the opposing frictional force will stop it from accelerating.
Im not even sure if I am on the right track though, and I cannot figure this out!
Thank you!
"Using this I said (5kg)(2m/s^2) = mew FN"
You forgot the 40 N pulling force.
ehild
What do you mean I forgot about the 40N force? Where would I put it in my equation?
Actually, If I go
(5kg)(2) = mewFN + 40N
-30N = mewFN
-30 / (-9.8 x 5) = .61
Thanks
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 45 ·
