Minimum friction coefficient for small block on sliding large block at 37°
63 replies · 9K views
gracy
:[/B]
block M slides down on frictionless incline .Find the minimum co efficient of friction so that m does not slide with respect to M.
:acceleration of the system=total driving force/total mass:
[/B]
m does not slide with respect to M means there should not be kinetic friction rather static friction.both small and big block will have same acceleration.
acceleration of the system=total driving force/total mass:total driving force=(m+M)g sin theta
acceleration of the system=(m+M)g sin theta/m+M
=g sin theta
force responsible for acceleration of small block would be force of static friction between two blocks.
Hence force of static friction between two blocks=mass of small block i.e "m" multiplied by g sin theta
but this force of static friction between two blocks is also equal to or smaller than μ multiplied by normal force on small block i. mg
force of static friction ≤ μmg force of static friction/mg≤ μ
m× g sin theta= force of static friction
Hence m× g sin theta/mg ≤ μ
theta= 37 degrees
sin theta ≤ μ
sin 37 degrees ≤ μ
0.601 ≤ μ
but the correct answer should be 0.75 ≤ μ
where am I going wrong?
[/B]
There are other forces acting on the small block besides friction. What is the direction of the friction force acting on m?
Draw a good free body diagram for the small mass m.
You correctly obtained the acceleration of both masses, which is oriented in the same direction as the incline. Can you resolve this acceleration into components in the horizontal and vertical directions? These are the horizontal and vertical components of the acceleration of the smaller mass m. Once you know these, can you do force balances on m in the horizontal and vertical directions? What do you obtain?
Chet
I think my diagram was wrong.Here I have corrected myself.
Your diagram is still awful. I thought I understood your original diagram. I'm still trying to figure out how to draw figures with whiteboard that can have straight lines. Meanwhile, please see if you can answer my questions in post #3.
I still don't know from your figure whether θ = 37° is the angle of the incline with the horizontal, or with the vertical. I assumed it was with the horizontal.
Chet
please point out my mistakes.
OK. That's all I needed to know. So now, back to post #3.
Chet
Is not mass M also a block? If it is a wedge as it was drawn, what are its angles?
Mass M is also a block.Sorry for my poor drawing.
I want to solve this as soon as I can.I don't have much time.I have a test tomorrow.
ehild said:
Is the set-up that shown in my figure?
Yes.Absolutely correct.
And is the problem text as you wrote? Is zero friction between M and the incline?
Yes.
Then is friction needed that m accelerate the same as M?
Sorry.I did not understand.
What force acts on m along the incline? What acceration does it cause without friction?
You mean excluding friction between the blocks what other forces are acting on m along the incline?
The two blocks have to move together, with the same acceleration. You have shown that the acceleration is gsin(37°).
If you suppose zero friction between the blocks, what would be the acceleration of block m?
Please tell me is my free body diagram correct in post 5?I don't think so.Please point out my mistakes in post 5.
Zero,as I think that it is the only net force acting on block m.
It is correct for the blocks as a single system, when they move together. To get the force of friction necessary acting on m you need to draw separate FBD-s for both blocks.
The net force acting on m along the incline is mgsin(37)-Friction. But you want m accelerate with a=gsin(37°), so you are right about the friction.
I meant to say Friction is the only net force acting on block m.Excluding fiction net force is zero.
ehild said:
gracy said:
Zero,
You can not switch off gravity. Gravity and normal force act on block m anyway.
I think I have solved the problem.May I show you how would I get 0.75 as coefficient of friction between blocks?
Show.
