MHB Proving Miquel's Theorem: Need Help!
  • Thread starter Thread starter pholee95
    Theorem
To prove Miquel's Theorem, one should start by identifying point M as the intersection of two circumcircles from the triangles AEF, BDF, and CDE. By drawing lines MD, ME, and MF, the properties of cyclic quadrilaterals can be utilized to demonstrate that M also lies on the third circumcircle. The theorem asserts that for any triangle ABC with points D, E, and F on sides BC, AC, and AB, the circumcircles intersect at point M. A reference to the Wikipedia page on Miquel's Theorem is suggested for additional insights. This approach effectively establishes the necessary proof for the theorem.
pholee95
I don't know how to start proving this theorem, so can someone please help? I need to prove that the circumcircles all intersect at a point M. Thank you!
Miquel's Theorem: If triangleABC is any triangle, and points D, E, F are chosen in the interiors of the sides BC, AC, and AB, respectively, then the circumcircles for triangleAEF, triangleBDF, and triangleCDE intersect in a point M.
I have attached here the figure of theorem.
Mathematics news on Phys.org
Have you looked at https://en.wikipedia.org/wiki/Miquel's_theorem? The trick seems to be to take $M$ to be the point where two of the three circles meet, draw the lines $MD$, $ME$ and $MF$, then use properties of cyclic quadrilaterals to show that $M$ also lies on the third circle.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
