Modal analysis of a pin-jointed frameworks
The discussion focuses on calculating modal frequencies for pin-jointed frameworks using the direct stiffness method in MATLAB. The user has generated a global stiffness matrix and is attempting to find eigenvalues by multiplying this matrix with an inverted mass matrix. There is confusion regarding whether the resulting eigenvalues represent the first six modal frequencies of the entire framework or if they pertain to individual trusses. Clarification is sought on the correctness of the stiffness matrix used and the values for Young's modulus. The user has also shared MATLAB files for further assistance in resolving these queries.
jackcolebrook
Hi
I'm trying to find the modal frequencies of a pin-jointed frames, to validate an ansys model.
So far I've used direct stiffness method to generate a global stiffness matrix for the framework in Matlab. Is it as simple as mutiplying the stiffness matrix with an inverted mass matrix and finding the eigenvalues?
My gut geeling tells me I'm missing a step. Any help would be great.
When:
Mass = M
Stiffness = K
Then:
vector(modal frequencies) = sqrt(eigenvals(K * M^-1))
Thanks for the help skeleton,
Could you take a look at my workings as see if I am talking cobblers.
If I use direct stiffness method, I can obtain a global stiffness for a framework. This is done by decomposing the frame into sperate trusses. Calulating the stiffness in local co-ordinates, then tranfering into global co-ordinates. Each truss is then arranged into a global stiffness matrix.
This global stiffness matrix now releates forces at each node with a displacements in x and y. Ordinarily I would then use this as a simple method to calulate displacements/stresses in a framework.
Ok, so this is where I get confused.
In my example I have 3 elements with 2 possible displacements at each node. This gives a 6x6 stiffness matrix for the frame.
So calculating f=sqrt(eig(K*inv(m)), gives 6 numbers.
Are these numbers the 1st 6 frequencies of the framework, or the modal frequencies in x and y for each truss? Or have I calulated the wrong stiffness matrix?
Thanks,
Your document wrote:
A=10mm dia bar (Area of strut)
Truss members would area, not diameter. So,
A = pi/4*dia^2 = 78 mm2
For structural steel,
Young's modulus: E = 200 GPa,
Shear modulus: G = 77 GPa
You wrote E=74 GPa. Your value is close to G, not E, of steel. Is that what you wanted?
The above two numerical changes would not change the "mechanics" of the equations, only the resulting values.
If you send me your MATLAB file then I'll look at it in answering your primary question.
Hi Skeleton
Apologies, should have been more clear on the document, my writing is terible!
74GPa is the young's modulas of Aluminum and area was based on a 10mm dia bar.
Attached are my MATLAB files. DSM01 set up the problem, truss2d returns a mass and stiffness matrix for a given element in global co-ordinates.
Thanks for the help,
J
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
