Modeling mass-spring-dashpot system
  • Thread starter Thread starter Kavorka
    Modeling System
The discussion revolves around solving a mass-spring-dashpot system characterized by the differential equation 25x'' + 10x' + 226x = 0, with initial conditions x(0) = 2 and x'(0) = 4. The characteristic equation yields complex roots, leading to a general solution involving exponential decay and trigonometric functions. Participants clarify the calculation of coefficients A and B, with A confirmed as 2 and B corrected to 62/45. The focus is on finding the smallest time t > 0 when x(t) = 0, with the solution requiring the equation Acos(3t) + Bsin(3t) = 0. The final consensus indicates that the calculations are correct, and the derived time value needs verification against earlier assumptions.
Kavorka
Suppose that the mass in a mass-spring-dashpot system with m = 25, c = 10, and k = 226 is set in motion with x(0) = 2 and x'(0) = 4. Find the smallest time t>0 for which x(t) = 0
mx'' + cx' + kx = 0
I rushed through this a bit due to lack of time today so there may be mistakes, I just need to be sure I'm doing this correctly.
The differential equation is: 25x'' + 10x' + 226x = 0
Which has the characteristic equation: 25r2 + 10r + 226 = 0
with roots: r = -(1/5) +/- 3i
Giving the general solution:
x(t) = e-(1/5)t(Acos(3t) + Bsin(3t))
Plugging in the initial conditions:
x(0) = 2 = A
x'(t) = -(1/5)Ae-(1/5)tcos(3t) -3A e-(1/5)tsin(3t) - (1/5)e-(1/5)tsin(3t) + 3Be-(1/5)tcos(3t)
x'(0) = 4 = -(1/5)(2) + 3B
B = 22/15
Finding combined solution:
x(t) = Ce-(1/5)tcos(3t-a)
C = (A2 + B2)1/2 = 3(346)1/2/15
a = tan-1(B/A) = 0.6327 radians
x(t) = (3(346)1/2/15)e-(1/5)tcos(3t - 0.6327)
If this is right (it seems too messy, might have messed up), how would I solve it when equal to zero?
For which you find A and B correctly A correctly.The first factor is > 0, so basically all you want to solve is
Acos(3t) + Bsin(3t) = 0​
And that's not so hard.
And if you want the other form, same thing: solving cos(3t - atan(B/A)) = 0 should be enough -- and give the same result :rolleyes:
Something's wrong with your general solution, though, so fix that first !
I checked again, and with Wolfram, and I did get A and B right. C should be 2(346)^0.5 /15 though. When I solve cos(3t - 0.6327) = 0, I get t = 0.7345 which isn't right. This answer x2 is right though, and I'm not sure why.
Edit: misunderstanding, my answer is right.
Yeah, B was 62/45. Well done!
  • · Replies 17 ·
