Modulator and Demodulator (conceptual question)?
  • Thread starter Thread starter neotriz
The discussion centers on the behavior of modulators and demodulators in signal processing, specifically regarding a 3kHz sinusoidal signal with amplitude A. It is established that while a perfect modulator and demodulator would produce an output identical to the original signal, real-world applications often result in amplitude attenuation. The participant observed an output amplitude of A/10 instead of the expected A/4, highlighting the importance of understanding system-specific gain values for accurate signal reproduction.
  • Understanding of modulation techniques (e.g., AM, FM)
  • Familiarity with signal processing concepts
  • Knowledge of gain calculations in electronic circuits
  • Experience with lab equipment for signal generation and measurement
  • Research the principles of Amplitude Modulation (AM) and Frequency Modulation (FM)
  • Learn about gain and attenuation in signal processing
  • Explore the characteristics of ideal vs. non-ideal modulators and demodulators
  • Investigate the impact of circuit design on signal integrity
Electrical engineers, signal processing specialists, and students studying communication systems will benefit from this discussion, particularly those interested in the practical implications of modulation and demodulation in real-world applications.
neotriz
Just a quick conceptual question.
If you have a sinusoidal signal of 3kHz with an amplitude of A, and it's going through a modulator, and then going through a demodulator, must the output of the modulator resemble exactly to the original signal?
The reason why I am asking is because when I was doing this in my lab, the output of the modulator had the same frequency of the original signal, but 1/10 of the Amplitude.
I thought it would have A/4 instead.
Comments?
It all depends on your system.
A perfect modulator and demodulator would result in an output that exactly matched the original signal.
In reality the demodulator stage may be such that you get a demodulated signal has an attenuated amplitude. Ideally this attenuation would be known and linear so that you can amplify the signal back to its original state.
So I guess I would say I need more detail to really answer better than that. Why did you expect A/4 to begin with? What type of modulation were you performing?
Never mind, I just calculated the gain for the modulator and demodulator.
The reason I thought it would be A/4 is because I remembered the professor gave us an ideal circuit diagram that had a specified gain value for both the modulator and demodulator.
Thank you for your input!
  • · Replies 28 ·
  • · Replies 46 ·
  • · Replies 92 ·
