Math Amateur
MHB
- 3,920
- 48
I am reading Paul E. Bland's book "Rings and Their Modules" ...
Currently I am focused on Section 4.2 Noetherian and Artinian Modules ... ...
I need some help in order to make a meaningful start on Problem 1, Problem Set 4.1 ...
Problem 1, Problem Set 4.1 reads as follows:
[/B]
Can someone please help me to make a meaningful start on Problem 1 above ... as well as clarifying the definition of one module generating another ... see my notes following ... ...
I am having a bit of trouble pinning down a definition from Bland that gives me the meaning of "a module ##M## generating a module ##N##" ...
Now ... on page 104 of Bland (see first page of Bland Section 4.1 below) we read the following:
" ... ... If ##\mathscr{S}## is a set of submodules of ##M## such that ##M = \sum_{ \mathscr{S} } N##, then ##\mathscr{S}## is said to span ##M## ... ... "
Now if spanning ##M## is the same as generating ##M## ... then in Problem 1 we could take ## \mathscr{S} = \{ M \} ## as generating ##N## ... but is that the correct interpretation of "span" and would the definition be useful in Problem 1 ... ?
Alternatively ... on page 105 we read in Definition 4.1.2 (see Bland's text displayed below ... )
" ... ... An R-module ##M## is said to be generated by a set ##\{ M_\alpha \}_\Delta ## of R-modules if there is an epimorphism ##\bigoplus_\Delta M_\alpha \rightarrow M##. ... ... "
Maybe this is the definition to use in Problem 1 above ... with ##\{ M_\alpha \}_\Delta = \{ N \}## ... ... is that the correct start on the problem ...?
Can someone please clarify the above ... and then, further, help me to make a meaningful start on the problem ...Help will be appreciated,
Peter==========================================================================================In order to give readers the definitions, notation and context of Bland's treatment of generating and cogenerating classes, I am providing access to Bland's Section 4.1 ... as follows ...
Hope that helps ...
Peter
