Molly's question at Yahoo Answers regarding projectile motion
The projectile motion discussion centers on a projectile launched at a 45° angle with a muzzle velocity of 94 feet per second. The maximum height occurs at a horizontal distance of 138.06 feet, yielding a maximum height of 69.03 feet. The total range of the projectile, where it strikes the ground, is calculated to be 276.12 feet. These results are derived using the parametric equations of motion and the specific values for gravitational acceleration.
  • Understanding of projectile motion principles
  • Familiarity with parametric equations
  • Knowledge of basic calculus for finding maxima
  • Ability to manipulate algebraic expressions
  • Study the derivation of projectile motion equations
  • Learn about the effects of varying launch angles on projectile range
  • Explore the impact of different initial velocities on maximum height
  • Investigate real-world applications of projectile motion in sports and engineering
Students in physics, educators teaching projectile motion concepts, and engineers involved in trajectory analysis will benefit from this discussion.
MarkFL
MHB
Here is the question:
A projectile is fired at an inclination of 45° to the horizontal, with a muzzle velocity of 94 feet per second?
The height h of the projectile is given by the following where x is the horizontal distance of the projectile from the firing point.
(a) How far from the firing point is the height of the projectile a maximum? Give your answer correct to the nearest foot.
(b) Find the maximum height of the projectile. Give your answer correct to the nearest foot.
(c) How far from the firing point will the projectile strike the ground? Give your answer correct to the nearest foot.
I have posted a link there to this topic so the OP can see my work.
Hello Molly,
The equation of motion has been omitted, so I will derive it, assuming the projectile's initial height is 0 ft.
I would begin with the parametric equations of motion:
(1) $$x=v_0\cos(\theta)t$$
(2) $$y=-\frac{g}{2}t^2+v_0\sin(\theta)t$$
To eliminate the parameter $t$, we solve (1) for $t$ and substitute into (2) to get:
(3) $$y=\tan(\theta)x-\frac{g}{2v_0^2\cos^2(\theta)}x^2$$
Now we have the height $y$ of the projectile as a function of the initial velocity $v_0$, the launch angle $\theta$ and the horizontal displacement $x$.
Using the given data and known data:
$$\theta=45^{\circ}$$
$$v_0=94\,\frac{\text{ft}}{\text{s}}$$
$$g=32\,\frac{\text{ft}}{\text{s}^2}$$
We then have:
$$y=x-\frac{8}{2209}x^2$$
a) To find where the height of the projectile is a maximum, we may simply find the axis of symmetry:
$$x=-\frac{b}{2a}=-\frac{1}{2\left(-\frac{8}{2209} \right)}=\frac{2209}{16}\text{ ft}$$
b) To find the maximum height, we may now evaluate the height function at the axis of symmetry:
$$y_{\max}=y\left(\frac{2209}{16} \right)=\frac{2209}{32}\text{ ft}$$
c) To find the range $r$ of the projectile, we may double the axis of symmetry, since this axis is midway between the roots:
$$r=2\left(\frac{2209}{16} \right)=\frac{2209}{8}\text{ ft}$$
  • · Replies 16 ·
27K
  • · Replies 53 ·
