Moment of Inertia about the line x=y
The problem involves establishing an integral formula for the moment of inertia of a two-dimensional material region with a given density about the line y=x. The original poster attempts to transform the moment of inertia calculation from the x-axis to the line x=y.
  • Participants discuss the correct formulation of the moment of inertia and the appropriate distance calculation from a point to the line x=y. Questions are raised about the transformation of the integral and the correct distance formula to use.
Participants are actively engaging in clarifying the correct approach to calculating the moment of inertia. Some have provided guidance on the distance formula, and there is a recognition of previous errors in calculations. Multiple interpretations of the distance and its implications for the integral are being explored.
There is a mention of a typographical error in the original formula for the moment of inertia, and participants are working through the implications of using the correct distance formula in their calculations.
Jadehaan
Let \Omega represent a two dimensional material region who density is given by \rho(x,y). Establish an integral formula for the moment of inertia of the material region about the line y=x.
The moment of inertia about the x axis: \int\intx2\rho(x,y)dA
I am attempting to transform the moment of inertia about the x-axis to the line x=y, how would I go about doing this?
Thanks for any help, Jim.
The moment of inertia is the integral of r^2 rho(x,y) dA where r is the distance from the point (x,y) to the axis. That means the expression you gave is the moment of inertia about the y axis, not the x axis. Now you have to replace r in the integral with the distance from a point (x,y) to the line x=y. How many ways do you know to find the distance from a point to a line?
Thanks for your help. You were right, I mistyped the formula for the moment about the x axis. Using points (x,y) and (y,x) I calculated r2=2x2-4xy+2y2 So the formula would be the integral of this multiplied by rho dA.
That seems close, but aren't you off by a factor of four there? The distance from (1,0) to the line x=y is sqrt(2)/2. Isn't it? So that makes r^2 for (1,0) r^2=1/2.
I see. I was using the wrong distance formula. So using the formula for the distance between a point (m,n) and a line Ax+By+c=0 the distance is r= |Am+Bn+C|/ sqrt(A2+B2)
Using the point (x,y) and the line x-y=0 I calculated the distance r=|x-y|/sqrt(2)
Does this sound correct?
Yes, that sounds correct. So r^2=(x-y)^2/2.
Yep, thanks so much Dick.
10K
