Moment of inertia around the z-axis
The discussion revolves around calculating the moment of inertia around the z-axis for a system consisting of a rod and a disk. Participants are attempting to derive the correct formula and address issues related to the setup and calculations involved in the problem.
  • Homework-related
  • One participant expresses confusion about their calculations for the moment of inertia, providing their work and seeking help.
  • Another participant questions whether the center of mass of the rod has been considered in the calculations.
  • Some participants suggest starting from the definition of moment of inertia and deriving it for a thin rod at an angle, indicating that the process may not be clear without a thorough breakdown of steps.
  • There are discussions about the correct limits of integration and the definition of the differential volume element in the context of the problem.
  • Participants point out that the density used in the calculations may not be correctly represented as a linear density, leading to confusion in the derivation.
  • Some participants emphasize the need to account for the distances between the centers of mass of the objects and the common axis of rotation.
Participants do not reach a consensus on the correct approach to calculating the moment of inertia. There are multiple competing views regarding the setup, the use of variables, and the interpretation of the problem.
There are unresolved issues regarding the assumptions made about the axis of rotation, the limits of integration, and the definitions of the variables used in the calculations.
cherry
Determine the moment of inertia about the z axis of the assembly which consists of the 1.5-kg rod CD and the 7-kg disk.
I_zz=int(r_z^2)dm
I am not getting the right answer and I don't know where I am going wrong. Help would be appreciated, thanks!
(My apologies if my equations are not formatted correctly, I am still having trouble using LaTex on here)
My work:
\mathrm{I}_{zz}=[\frac{1}{12}(1.5)(0.2)^{2})+1.5(0.1sin(26.56))^{2}]+[\frac{1}{2}(7)(0.1)^{2}+7(0.2sin(26.56))^{2}]=0.09898{kg}\cdot{m^2}
Correct answer:
\mathrm{I}_{zz}=0.0915{kg}\cdot{m^2}
Are you considering the location of the rod's center of mass?
I think it would help you ( for starters) if you tried to derive the mass moment of inertia of a thin-rod about a vertical axis passing through its center at some angle ##\theta## from horizontal using the definition:
$$ I = \int_V \rho r^2 ~ dV $$
It's not easy to tell where you are going wrong without steps, thought process, and working equations in Latex... So lets just start from the beginning.
cherry said:
Homework Statement: Determine the moment of inertia about the z axis of the assembly which consists of the 1.5-kg rod CD and the 7-kg disk.
Relevant Equations: I_zz=int(r_z^2)dm
My work:
$$ \mathrm{I}_{zz}=[\frac{1}{12}(1.5)(0.2)^{2}) +1.5(0.1\sin(26.56))^{2}] +[\frac{1}{2}(7)(0.1)^{2}+7(0.2\sin(26.56))^{2}]=0.09898{kg}\cdot{m^2}$$
Correct answer:
Fixed your Latex.
You enter that with the following code:
Code:
See: LaTeX Guide
The center of mass of a thin rod is at L/2.
My derivation for the mass-moment of inertia of a thin rod about a vertical axis based on the diagram provided is the following (x is along the axis of the rod):
$$ \rho=\frac{m}{L} \longrightarrow dm=\frac{m}{L}dx $$
$$ I=\int_V{\rho r^2}dV $$
$$ I=\int_{0}^{L}\frac{m} {L}dx\cdot(xcos\theta)^2 $$
$$ =\frac{m}{L}cos^2\theta\int_{0}^{L}x^2dx $$
$$ =\frac{m}{L}cos^2\theta(\frac{1}{3}L^3) $$
$$ I=\frac{1}{3}mL^2cos^2\theta $$
Based on the question, theta ends up being:
$$ \\\theta=90-tan^{-1}(\frac{0.1}{0.2}) $$
$$ =90-26.565 $$
$$ \theta=63.43 $$
Please let me know if I'm on the right track! Thank you.
$$ =90-26.565 $$
$$ \theta=63.43 $$
I was asking for a derivation about a central axis. Also, your element ##dV## doesn't seem to make sense. Neither do your limits of integration.
Just say the cross-sectional area of the element is ##A##, and the uniform density of the bar is ##\rho##, and they are both constant with respect to ##r##. Try again for the axis shown in the diagram.
Actually lets just take it piece by piece. What is ##dV## ( the volume of the differential element in red) in terms of ##dr##? Remember, ##r## is perpendicular to the axis of rotation. Just write me the integral (without limits), with the constants factored out.
That is correct respect to the lenght of the rod.
But it is not in a horizontal position.
You would need to use the distances between the centers of mass of both objects and the common axis of rotation.
So, ##\rho## isn't a linear density in the equation. ##dm = \rho dV##, so that was confusing for me. I also see that you have transformed to ##x## along the length of the bar instead of keeping with ##r##. Ok.
Your main issue here is that you have the limits of integration incorrect (as @Lnewqban is pointing out) for the axis in the diagram. You are unwittingly computing ##I## about an axis passing through the end of the bar. Which is what you have in your problem, but not what I asked.
  • · Replies 28 ·
