Moment of inertia tensor calculation and diagonalization
The discussion focuses on calculating the moment of inertia tensor for a rigid body represented by three point masses and diagonalizing the resulting matrix. The initial calculations provided an inertia tensor matrix, but the user expressed uncertainty about the accuracy of their eigenvalue results, which yielded complex decimal values. A suggestion was made to recalculate the coordinates relative to the center of mass rather than the origin, which could lead to more precise eigenvalues. The conversation highlights the importance of correctly accounting for the center of mass in such calculations. Ultimately, recalibrating the approach could yield clearer results in future calculations.
BiGyElLoWhAt
Not sure if this is advanced, so move it wherever.
A certain rigid body may be represented by three point masses:
m_1 = 1 at (1,-1,-2)
m_2 = 2 at (-1,1,0)
m_3 = 1 at (1,1,-2)
a) find the moment of inertia tensor
b) diagonalize the matrix obtaining the eigenvalues and the principal axes (as orthogonal vectors)
##I_{ij} = m_{\beta}(\delta_{ij}r_{\beta}^2 - x_{i\beta}x_{j\beta})##
##\vec{A} = \vec{P^{-1}}\vec{D}\vec{P}##
##I_{ij}=I_{ji}##
I'm going to drop the beta's, but each xyz is associated with the mass attached to the term.
##I_{00} = m_1(x_0^2 + x_1^2 +x_2^2 - x_0^2) + m_2(...) + m_3(...)##
## = 1(5) + 2(1) + 1(5) = 12##
##I_{01} = m_1(-x_0x_1) + m_2(...) +m_3(...)##
##= -1(-1) -2(-1) -1(1) = 2##
##I_{02} = m_1(-x_0x_2) + m_2(...) + m_3(...)##
## = -1(-2) -2(0) -1(1) = 4##
##I_{11} = m_1(x_0^2+x_2^2) + m_2(...) + m_3(...)##
##= 1(5) +2(1) +1(5) = 12##
##I_{12} = m_1(-x_1x_2) + m_2(...) +m_3(...)##
##= -1(2) +2(0) - 1(-2) = 0##
##I_{22} = m_1(x_0^2 +x_1^2) + m_2(...) +m_3(...)##
##=1(2) +2(2) +1(2) = 8##
This gives me
##\vec{I} = \left (
\begin{array}{ccc}
12 & 2 & 4 \\
2 & 12 & 0 \\
4 & 0 & 8 \\
\end{array} \right )##
and
##det(I_{\lambda}) = 0 = -\lambda^3 + 32\lambda^2 - 316\lambda + 928##
I don't even know how to solve that equation, and online calculators give
diagonal(5.35139, 11.2841, 15.3627)
Did I mess up? There's nothing about using a calculator, but I don't know how else to solve this. Did I mess up? I am pretty sure I'm not supposed to end up with a bunch of stupid numbers like this.
For what it's worth, I got the same matrix you did.
Well, maybe I'll just roll with it then. I thought I checked all my algebra carefully. I'm pretty sure I'm supposed to use P^-1 D P to get the diagonal since he said "obtaining the eigenvectors", but maybe I'll just do row operations or something to avoid the decimals. Thanks.
Not sure but it looks as if you are using vectors with respect to the origin. Shoudn't you be using vectors relative to the center of mass of the system
instead (for mass 1) of x0 = 1 x1 = -1 and x2 = -2 in line 1 of your calculation: try x0 = 1 - x0cm = 1 - 0 = 1 x1 = -1 = x1 cm = -1 - 1/2 = -3/2 and x2 = -2 - x2 cm = -2 - -1 , etc.
this means a lot more calculation because you need to subtract off the center of masses but I think it will lead to a better answer. On the other hand, I'm glad I am not doing the calculation.
I ended up with eigenvalues 11; 11/2 +/- sqrt(57) / 2.
Likes BiGyElLoWhAt
That is a lot neater. I didn't think about doing that. I will keep it in mind for next time.
  • · Replies 28 ·
  • · Replies 29 ·
