Moments Problem Regarding Sign Convention?
The discussion revolves around a moments problem involving the calculation of the moment of a force applied to a hammer's handle about a specific point. Participants are examining the sign convention used in the context of clockwise and counterclockwise moments.
  • The original poster attempts to apply the principle of moments but is confused about the sign convention when breaking the force into components. They question how to determine the signs for each component in their calculations.
  • Some participants suggest using the right hand rule to clarify the direction of moments produced by each force component.
  • There is a discussion about the physical interpretation of the right hand rule and its application in determining the sign of the moments.
  • Participants express uncertainty about the orientation of their hands and the resulting direction of their thumbs when applying the right hand rule.
The conversation is ongoing, with participants sharing insights about the right hand rule and its application. Some guidance has been offered regarding the interpretation of the rule, but there remains a lack of consensus on its practical application, as participants continue to seek clarity on the signs of the moments.
Participants are working within the constraints of a homework assignment, which may limit the information available for discussion. The original poster's confusion about sign conventions and the right hand rule indicates a need for further exploration of these concepts.
-overrated
The handle of the hammer is subjected to the force
of F = 20. Determine the moment of this force about the
point A.
http://s3.amazonaws.com/answer-board-image/3214a2db-1a55-4648-b582-5f36f0f34451.jpeg
Principle of moments: Mo = FxY - FyX
I have broken the force into x and y forces
and using the Principle of moments: Mo = FxY - FyX
I have gotten 20cos30(18)-20sin30(5) however in the solution manual the answer is -20cos30(18)-20sin30(5). How do I know where to put what signs in these kind of equations. I know that positive is CCW and negative is CW but when broken into components how do you know what signs to use?!
Use the right hand rule for each component of force. Both components produce clockwise moments about A, hence , both moments are negative using the convention you have chosen. Forget about the minus sign in your relevant equation. You decide whether plus or minus.
I wasn't really able to grasp the idea of the right hand rule. My professor is always just waving her hands around and didn't explain it well enough, can you explain to me quickly how I would use the right hand rule?
Yeah, you've got to waive your right hand around a lot to properly twist it in the correct orientation, sometimes nearly straining your wrist, which is the case here when determining the sign of the sin component of the force. It takes some practice. The cos comp of the force acts up and rightward, the sin comp acts up and leftward.
You will find several definitions of the right hand rule. With your 4 fingers of your right hand extended and the thumb extended perpendicular to the fingers, place your fingers pointing in the direction of the force component along the line of action of that force component , and then curl your fingers toward the point you are taking moments about. In so doing, if your thumb points inward toward you, the moment is ccw; if it points outward away from you, the moment is cw. If you can't curl your fingers toward the pivot point, flip your wrist 180 degrees. Don't sprain it.
Aha, thanks Jay! I think I got the hang of it, but yeah definitely it does hurt your wrist. I did catch my thumb slightly pointing towards me which is a good sign because they were both clockwise.
You mean pointing away from you, no?
Darnit, on second thought maybe I do not have it then. My fingers are pointing up to the right regarding the cosine and I curl my fingers towards point A my thumb sort of goes to the left I am not sure if I can say if its outwards or inwards.
Once you point your fingers in the direction of the line of action of the force component and curl them toward the pivot point, your thumb is pointing into the plane of the computer screen, into the 3rd dimension or z axis. That's what i meant by away from you.
Yes, now I do think I have it straight, sometimes the direction at which my thumb points can be a bit ambiguous.
Yes, it can be ambiguous. But when looking into the third 'z axis' dimension , the words 'left' and 'right' lack meaning.
9K
23K
