Momentum Conservation: Ball & Wall Impact
The momentum of a ball at the exact moment it contacts a wall is zero, as all particles of the ball reach a state of zero velocity when fully compressed. This scenario assumes a perfectly uniform ball, where the instant of contact allows for no movement before rebound. While there may be a minuscule momentum imparted to the wall, it is negligible at the point of full compression. The discussion emphasizes the importance of this instant in understanding momentum conservation during impacts. Ultimately, the ball's momentum is zero at the moment of maximum compression.
Hannah7h
What is the momentum of a ball at the exact point where it comes into contact with a wall?
Assume that the ball is so uniform that there is an instant of time when all particles of the ball have come to a zero velocity, fully compressed, and about to rebound. At that instant the momentum is 0. (I am ignoring the velocity that the ball imparts to the wall. Otherwise, there is some tiny momentum at the time of full compression and particles of the ball will not have 0 velocity till a small amount of rebound has begun.)
Thank you!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
