Momentum of Astronaut and Satellite
The discussion centers on calculating the initial distance from a space shuttle to a 92-kg astronaut after the astronaut pushes a 1200-kg satellite, achieving a speed of 0.14 m/s. Using the momentum equation (m1)(v1) = (m2)(v2), the participants identified errors in their calculations, particularly with decimal placement and vector direction. The final confirmed distance calculated was approximately 13.7 meters, emphasizing the importance of precision in physics problems.
  • Understanding of momentum conservation principles
  • Familiarity with basic physics equations involving mass and velocity
  • Knowledge of scalar and vector quantities
  • Ability to perform unit conversions and handle significant figures
  • Review momentum conservation in isolated systems
  • Study the impact of vector direction on physics calculations
  • Learn about significant figures and their importance in scientific calculations
  • Practice solving physics problems involving multiple objects and forces
Students studying physics, educators teaching momentum concepts, and anyone interested in improving their problem-solving skills in mechanics.
LastXdeth
A 92-kg astronaut and a 1200-kg satellite are at rest relative to the space shuttle. The astronaut pushes on the satellite, giving it a speed of 0.14 m/s directly away from the shuttle. Seven-and-a-half seconds later the astronaut comes into contact with the shuttle. What was the initial distance from the shuttle to the astronaut?
(m1)(v1) = (m2)(v2)
(1200)(14)=(92)(v2)
(v2)=182.61
d= vt
d=182.61*7
d=1278.26 m (Is this right?)
What does your gut tell you about that answer? How far is that?
Does that seem right - considering the velocity and time involved?
If no, go back and check all your numbers.
And your decimals.
And your decimals.
Oh, wow, another careless mistake like on my previous question...So, besides the "decimal manipulation", are there any other errors like lack of vectors (negative and positive). I am having a dilemma on whether to make v1 negative since it's going the opposite direction.
There's also a delta-t issue.
As for neg and psotive, I suppose it depends on how rigorous you need your work to be. If you just need to supply the value, it'll work out.
I guess I just need the scaler quantity. Thanks for notcing my Δt error also. I need to read the questions more carefully.
By the way, I got my answer to be 13.725 meters if someone can confirm.
Hm. I get 13.7 - and that's rounded up from 13.695.
Ah. I see. Sig digs.
I did 1.826*7.5.
You did 1.83*7.5 = 13.725.
Well, it still rounds to 13.7.
DaveC426913 said:
Hm. I get 13.7 - and that's rounded up from 13.696.
It's just my lazy rounding error. Thanks for the confirmation!
