Momentum operator eigenstates/eigenvalues
  • Thread starter Thread starter space-time
    Momentum Operator
space-time
As far as I know, the momentum operator is as follows:
-iħ(∂/∂x)
Now let's say that I enact this operator on the famous solution to the 1-D particle in a box example:
Ψ= squrt(2/L) sin(πnx/L)
If the momentum operator operates on the above wave function, it yields:
-iħ * squrt(2/L) * (πn/L) * cos(πnx/L)
Now, it is true that squrt(2/L) * cos(πnx/L) is actually a solution to the 1D time independent Schrodinger equation that yields the energy eigenvalue E when you enact the Hamiltonian operator on it. However, it is still different from the original wave function (with sine in it). That is why I question whether or not the momentum operator operates on the same eigenstates as the Hamiltonian operator (since by definition of eigenstate, the result of enacting the operator on the wave function must yield an eigenvalue multiplied by the original wave function). So tell me:
Do the Hamiltonian and momentum operators work on the same eigenstates?
If not, what are the eigenstates of the momentum operator?
Generally no. Its only true in the case of a free particle.
The solutions to the eigenvalue equation P|p> = p|p>. If you expand |p> in terms of position eigenstates you get - well I will leave it as an exercise - its pretty basic and instructive. It is found in many texts eg page 96 of Dirac - Principles of QM which is simply the first text that came to hand.
If you think a bit deeper about the result you will realize its rather problematical (hint - they are supposed to be elements of a Hilbert space).
Post back here with the exact problem and we can have a chat about that - best in a separate thread so it can be examined independent of your original question.
Thanks
Bill
Be warned, however: On the finite interval there is no momentum operator. The operators, representing observables, must be self-adjoint! Unfortunately, you find misleading statements concerning a momentum operator on a finite interval quite often in textbooks, which is very bad.
Likes bhobba
To expand a little bit this comment. Mathematically, you can choose a dense subspace ##D(B) \subset L^2(0,b)## such that the "operator" usually described as:
##B: D(B)\subset L^2(0,b) \to L^2(0,b)##
##B(f(x)):=-i \frac{d f(x)}{dx}##
is (an unbounded) self-adjoint operator.
In fact there exist infinitely many different dense subsets ##D\subset L^2(0,b)## such that the "expression" ##-idf(x)/dx## give rise to a "different" unbounded self-adjoint operator.
This is possible for the finite interval with periodic (or quasi-periodic) boundary conditions,
$$\psi(x+L)=\exp(\mathrm{i} \varphi) \psi(x), \quad \varphi \in \mathbb{R},$$
but not for the potential box with infinitely high walls, where the boundary conditions are
$$\psi(x)=\psi(L)=0.$$
Exactly.
Yes. Mathematically you can define ##D(B):=\{ f\in L^2(0,b) : f \in AC(0,b), f'\in L^2(0,b), f(0)=f(b)\}## (or ## f(0) = c f(b)## for some given unit complex number c in the other cases).
Yes, none of those domains (suitable to define ##-idf(x)/dx## as an unbounded self-adjoint operator) are included in the set ##\{ f\in L^2(0,b) : f(0)=0=f(b)\}##
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
