Galaxion
- Messages
- 2
- Reaction score
- 0
- TL;DR
- Momentum physical meaning
Can momentum considered as the resistance of a force? Why?I noticed that the physical meaning of momentum and inertia are similar
Momentum is frame dependent; the velocity is relative to a reference velocity. Your "rest" is not a particularly special situation (to a Physicist).Matterwave said:A body at rest still has inertia even though it has no momentum.
I doubt that the answer to your question, whatever it may be, will help you in any way when setting up the system's equations of motion.Galaxion said:TL;DR: Momentum physical meaning
Galaxion said:the resistance of a force?
I think that would be mass. Resistance comes from Ohm’s law: ##V=RI##. If you analogize a force in Ohms law you would probably say a force is analogous to the voltage.Galaxion said:TL;DR: Momentum physical meaning
Galaxion said:I noticed that the physical meaning of momentum and inertia are similar
When trying to use an analogy to explain something then it is important that the analogy is valid. Ohm's Law states that the ratio of V/I is constant for a metal at constant temperature. That ratio is referred to as the Resistance. Merely quoting the ratio of volts to current in any old conductor is not "Ohm's Law" because V is not always proportional to I. I have come to terms with this sloppiness being common on PF but, in this context you really have to question the validity of quoting Ohm's law. It's rather the reverse actually: Newton's second law is a law because mass doesn't change but an invariant Resistance is a very rare occurrence.Dale said:Resistance comes from Ohm’s law: V=RI.
momentum and inertia aren't the same quantity!Galaxion said:TL;DR: Momentum physical meaning
The word 'resistance' has an implication of energy loss - as in electrical and frictional resistance. If you really want to use a form of words then why not 'reaction' (like Sir Isaac).Yug Ahuja said:inertia is more of an abstract term, basically the resistance to motion
Well - there you go. A very good reason not to include inertia in Physics teaching. Otoh, if a student brings up the word there it can be dealt with appropriately, stressing that it's not a term that's used today, for good reasons.Yug Ahuja said:I, myself, was confused first between 'inertia of motion' and 'momentum'.
